Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Temperature set to 33 but only gets to 40
Won't let me enter the real model number, 25344383405
The refrigerator is set to 33 but using another thermometer it is only 40-42 inside the refrigerator. Freezer varies from 2 to 8 (set to 0). Technician said compressor was not switching to high speed. Turned it off and it then came on at high speed. He said if that didn't fix it the control board would need to be replaced but said to wait and see. Since it won't achieve the temperature, I think it's the thermostat. Since it is digital I guess I have to replace the whole board. I was wondering where this board was so I could replace it myself. Or is this job too complicated. Also, will this fix the problem?
    Scholar:
  • 62 Answers
You have a Sears ref. You didn't state that the service you used was Sears. Why I ask is because if you have a problem with the electronics -- the cost of guessing with these parts is expensive and there is generally no return on those parts. My suggestion is to call Sears and ask for the "Service smart agreemment" it is a pre-pay costing in the in the 200+ dollar area but will give you a repair value of 500 per call for a year. Plus you know it will be fixed and working. startingwith the second trip, if needed, there is a food loss payment with the policy.
Posted on Dec 07, 2008
Refrigerator temperature too cold. Why can't it be reset?
When a thermistor is defective or a damper that regulates cold air from freezer becomes stuck or defective the temps can go really low and out of control. What is your model number?
Appliance 911 Sea Breeze
Jul 30, 2015 | Refrigerators
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How do I set the temperature on a true refrigerator model GDM-26EM?
40 degree is a perfect temperature for produce if its lower that stuff will turn brown. Maybe you thermometer has failed. Go to the food store and get a red stick and put it in there. Then adjust with that temperature indication. Hope this helps and good luck.
May 09, 2014 | True Refrigerators
My air conditioner won't cool down
I Think when it goes back to 33 thats your ambient temp . the temp in the room thats its trying to get down to .
If you set it on 22 . and just ignore the 33 it does it stay on cooling ?
Jan 30, 2012 | Heating & Cooling
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
The back of the fridge is frozen and food is not getting cold anymore
Try this first:
Self Diagnostics
You need to cycle your freezer display to indicate 0 and your refrigerator display to 7.
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display.
If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
Thermistor test sequence is:
1. Fresh food top thermistor
2. Fresh food bottom thermistor
3. Quick chill thermistor (displays 0 if unit is not equipped with Quick Chill option)
4. Evaporator thermistor
5. Freezer thermistor
Note: Thermistor test results will be displayed in the sequence shown above. The thermistor test sequence number will not be shown on the display.
Note the failures if any. Should ANY of thermistors fail you must replace it.
Having said that... at this point your stick with doing a manual defrost by unplugging the unit and directing a fan into the compartment for just over 2 hours to make sure ALL of the ice on the coils and in the drains has melted. (Yes it makes a water mess!)
After the manual defrost restart the unit / plug it in and once the compressor starts listen for the evaporator fan when the door switch is actuated and the condenser fan in the bottom of the unit any time the compressor is running. If either of the fans are not running you must find out why. Can be a door switch, motor winding or power to the motor. The door switch does not affect the condenser fan.
Finally if the unit is not automatically defrosting due to a component failure... i.e
Heater, themistor, or wiring you will see ice build up again in 2 to 3 days again and you will have to keep going through the manual defrosting routine until the automatic defrosting problem is resolved.
Thanks for choosing FixYa.
Kelly
Mar 27, 2011 | GE Profile Stainless Bottom-Freezer...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not working; icemaker not making ice. Temp set at 26
If the control board for the temperature control is not working it is a sign that the board inside the fresh food compartment is defective. WR55X10522 or part number 1170076
Your parts and help are listed here. My email appliancepartsoutheast@live.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just click on the Repair Clinic Man and enter your part or model number or enter the WR55X10522 into the parts and model search feature on the http://servicepartstec.blogspot.com/ site and enter FIND IT
Thanks, if you need more help let me know. I have not been getting notice of any replies from Fixya since they changed over to newer server. I will check back a couple days to see if you replied or if you need assistance contact me through my email. Thanks, Sea Breeze
Aug 09, 2009 | GE Profile PFS22 33" Artica French Door...
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
First, run the control and thermistor test:
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
• P = Pass
• 0 = Failed
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
