Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Panasonic PT43LC14, blinking green light on the power button
Howdy all,
The unit powered off and will not power up, just get the blinking green light on the power button. Purchased the unit in Nov 2004 and have replace the lamp assembly one time. I'd like to replace only the bulb this time around, if needed, but am having difficulty finding a quality source; suggestions are welcome.
Noting the symptoms mentioned, will a bad lamp prevent power up? or is there another possibility, perhaps a bad ballast?
Thanks for taking a moment.
  • 06020 Jan 29, 2009
    Where can I get a new ballast for this tv?
  • Panasonic Master
  • 5,138 Answers
Depends on how much tv you watch, lamps burn out after anywhere from 5,000 up to 8,000 hours also you xould have a bad fan if fan does not work lamp will not come on.
Posted on Dec 04, 2008
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Panasonic PT43LC14 blinking green light on power button
Check your FAN if fan does not work Lamp will not come on ,also Lamps only last 5,000 up to 8,000 hours so every hour that set plays the lamp timer is counting .Go to E-Bay you can find lamps 99.00
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
Panasonic pt43lc14 lamp blinking yellow
Lamp, Ballast or power supply are first things to inspect.
May 04, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Dec 03, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
371 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
