Problem for Dell (F3534) Touchpad
Dell Inspiron 640M E1405 Touchpad Issue
Touchpad itself and the driver are fine as far as I know. But the left touchpad key appears to be broken (no spring action; key sticks down). I've only had the computer for 2 years, though. Is it normal for a touchpad key to ware out so quickly?
How can I deal with this problem? Can the keys be cleaned or replaced, or will I have to put an entirely new tochpad assembly in the computer? How much does it cost?
Jesse
Same Problem
Apr 30, 2009
-   Same exact problem. My left touchpad key is now extremely sensitive and sometimes clicks on links online spontaneously. -   Guest Apr 24, 2009
-   The left touchpad button has no spring action and doesn't always work. Plus I have had several hinge issues with my Inspiron 640M.
dvuicich Mar 23, 2009
-   Same thing happened to my left touchapd button on my Inspiron 1525 7 months after buying it new. Dell told me since I wasn't under their Complete Care warranty it would cost me $250 to replace.Glad to know there's a do-it-yourself solution.
I hope Dell does something about this soon.
mangekyou009 Mar 15, 2009
-   Dell probably needs to have a recall or something because although it may not be many, it is still too many people with the same problem. I am literally holding the pieces of the left touchpad key in my hand!!! I am very frustrated also. Egads, what do i do!!!
RainaG Mar 06, 2009
-   I've had this computer (inspiron) for 3 months and I ran in to the same problem. The leftside button is draving me crazy. The spring cave up immediatly. I am really frustrated.-
pararesearch
Best Solution
posted on Mar 23, 2009
Rank: Apprentice
Rating: 100%, 3 votes
OK, it's not THAT difficult to replace the mouse button. I didn't have the ambition to follow Frumper's suggestion of replacing the little rubber dome with a spring, but there are a number of these available on ebay for under $30. If you're lucky, you'll find the whole top plate with the touchpad and mouse buttons - that saves a little time. But the disassembly/reassembly isn't too bad - there's a pdf of the disassembly process out on the web somewhere; if a google doesn't find it I can send it along. Basically, there are a LOT of little steps, and of course, everything is tiny and fragile. But what it entails is removing all the screws from the bottom of the machine - except for the two under the battery, they're identical. Don't forget the ones under the modem and CPU covers. Remove the 4 screws holding down the heatsink to the cpu. Pop out the hard drive. On the top side, pry off the plate with the power button, GENTLY remove the LCD plug and the 2 backlight connections. Then you can remove the 4 screws that hold the LCD assembly in place - put it somewhere safe! The keyboard will pop right up - be careful with the keyboard connection, the connector hinges, whereas most of the others have a locking key. With the keyboard out of the way, there are a final 4 screws holding the palmrest in place. When they're removed, disconnect the ribbon wires and just pry gently around the edge - starting at the back - and the whole palmrest will come off. If you've got a new palmrest assembly, you're ready to reassemble. If you've just got the mouse buttons, you'll have to remove the (4?) screws holding the front subframe to the palmrest, and a couple more ribbon connectors. Be VERY gentle with all the ribbon wires, and it goes back together very simply. I've done this a few times now; the first one took about 2 hours as I tried real hard not to break anything. Now they go in well under an hour. Like Frumpy said, not for the faint of heart, but not exactly rocket science either. Good luck!
Was this helpful?3 people thought this was helpful
Solution #2
posted on Jan 10, 2009
Rank: Apprentice
Rating: 88%, 2 votes
Hey, we just dealt with this on our E1405 - the mouse button uses a rubber dome like a keyboard to provide the spring action. What happened is the top of that dome separated from the rest of it and broke the "spring" action. So, you're left with no spring action and pushing the button shoves the broken piece into the membrane switch enough to make it trigger. It bugged me and the wife enough that I tore the whole thing apart to see if I could fix it. Well, let's just say that the touchpad button might be the single hardest thing to get to on the whole laptop - seriously. What I ended up doing after getting it all apart was replacing the rubber dome with a small spring I had from some past project and hotgluing a little nub in there to depress the membrane. The action is a little harder than the rubber dome, but it does spring back and the button still works. This is not for the faint of heart - there are a ton of screws and tiny little connectors to deal with. I think there is a replacement part available here:
http://tinyurl.com/palmrestIt says it includes the touchpad and buttons, but it's $75 and that was a bit salty for me. So, my recommendation - if you're good with taking things apart and don't mind risking bricking your laptop, give it a shot fixing it or trying the replacement part, otherwise, learn to live with the no-spring button or get a nice mouse. You can also tap the trackpad as another solution.
Was this helpful?1 person thought this was helpful
Solution #3
posted on Nov 02, 2009
Rank: Guide
Rating: 0%, 0 votes
I'm a laptop rebuilder and I specialize right now in refurb and reselling the Dell "e" series, 1405, 1505, and 1705s. The only 2 solutions I would cosign on are the full touchpad assembly replacement or the mod done with a spring. I'm fortunate enough (or NOT, LOL) to end up with spare rubber domes from encountering so many machines.
Here's the kicker for you first time folks on your disassembly. The e1405 has some of the trickier ribbon cable ZIF connectors I've seen. Be VERY careful to notice that the tiny gray U-shaped plastic "cable holder clips" are underneath the ribbon cables and cannot be seen properly even with a magnifying glass. Gently use a fine pair of tweezers on either side of the ribbon cable at the bottom of the the little ribbon cable plug housing to ease these clips out. Once you do one, you get the hang of it.
The first time I attempted this repair, I pulled the connector up halfway off the motherboard breaking some tiny circuits. I felt like a troglodyte. :)
Good Luck
Solution #4
posted on Mar 06, 2009
Rank: Apprentice
Rating: 0%, 0 votes
OK Guys, I have an INSPIRON 1525
My right side touchpad button was deffected from the day I opened the danm box with my so-called new computer. Anyhow, today March 6, 2009 at about 2pm (CST) I finally went through a nervous break down due to this stupid bottom. Went on-line to get help from Dell, company I bought the computer from, but as usual, no help was provided. Anyhow, found this website and was encouraged to fix this myself. Took off all screws at the bottom of my laptop and had enough space to see the bottom of the touchpad and where the two buttons sit.
1) I grabed a screw driver and literally and gently, listed the thin metal plate where touchpad and the buttons sit.
2) You decide how much pressure you want to apply as I came to see, the more pressure, the higher the buttons came to stick out, which in my case, was awesome.
3) I did not have to replce any parts and or purchase anything.
4) Personally, I did not find this procedure hard at all. Just remove all screws, gently lift the cover that surrounds your touchpad so that enough space is available. Insert the crew driver or any other tool, and lisft the flat thin metal plate where your touchpad and your buttons sit.
Good Luck
Guillermo Fuentes
Popular Solutions for Dell Touchpad
Questions and Unsolved Problems for Dell Touchpad
Do you recommend Dell (F3534) Touchpad?
When I use my touch pad, my mouse jumps all over the screen
stop tapping on my dell laptop
touch pad not working thumb pad and mouse pointing device not working
My touchpad no longer scrolls or zooms like it used to, and it switches where I am typing sometimes,...
(More)
My touchpad no longer scrolls or zooms like it used to, and it switches where I am typing sometimes, just if I accidentally brush it with my hand.
I have Dell laptop and the buttons for the left and right click on the touchpad stopped working. The...
(More)
I have Dell laptop and the buttons for the left and right click on the touchpad stopped working. The touchpad part itself still works and I can left click by double tapping on the touch pad still but the actual buttons do nothing.
8 Other Users Have The Same Problem - Continued
Comment by vinnyf, posted on Feb 18, 2009
thanks Frumper - I just noticed the same problem in my e1405. Been looking for a replacement touchpad - seems like there's a vendor on ebay selling a pad for the 1505 that sure looks identical - about $15, shipped, used - if it fits. I'll try one in a couple of weeks and post back if it works.
Comment by lat1954, posted on Jan 26, 2009
Same problem. My Dell Inspiron 640m Left button on the touchpad is also broke. It causes my cursor to have a mind of it's own. Is it that difficult to replace? I am somewhat mechanically inclined.
Comment by techiemanage, posted on Jan 05, 2009
My left key for the touchpad has lost its spring action. Not sure if this is due to a liquid damage.
