Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung RF267AAWP refrigerator makes strange noise intermittently
Samsung RF267AAWP refrigerator (1 year old) makes strange noise intermittently. It sounds like someone putting down a glass on a counter top. It happends about every 15 to 30 min approximately. It's a very annoying qiurk for such an exspensive refrigerator!!!
It sound like it it coming from around the ice maker?
Thank you for your help.
Mary
  • Anonymous Jan 08, 2009
    I have the same problem. I have a repair person coming out for the second time. I will post if I have an answer.
  • Anonymous Jan 09, 2009
    Did you find out was wrong with your samsung?
hotuna
  • 288 Answers
SOURCE: Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Posted on Nov 05, 2007
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
SOURCE: A clunking sound like ice cubes dropping. No ice maker in fridge.
there is a damper door assy that allows the cold from the freezer to the refrigerator,this may be sticking from shipping foam or tape that has never been removed from shipping, the install team almost allways rush and never really install correctly no do they explain how to use and care for the appliance, so check these things. in addition there is a know issue of the refrigerant lines having a slight restriction in them thus causing a autable sound coming from the evaporator and capillary line,this is located in the frezzer and will sound like its coming from all over. call bake the service co. & have them remove & reinstall the evaporator.
nbcrca:)
Posted on Apr 12, 2009
woodchuck789
  • 4070 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
Model #rb215lash
I know nothing about your model, but in my experience with refrigerators over the last 40 years, they can make a whole range of different noises at different times. There's even a note in the manual of my GE side by side something to the effect that strange noises are to be expected. I'm amazed at the range of different sounds that comes from our 10 year old GE. It's hard to say ignore noises because I never ignore a new noise from my car, but unless the same noise repeats under similar conditions, I'd not rush into trying to 'fix; it.
Apr 14, 2014 | Samsung Refrigerators
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
The refrigerator make noise. It seem to be from the motor. It is only 1 year old.
I think that sound come of the fan in the freezer. This sound is intermittant. It's possible that problem is cause by a defect bearing?
May 19, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool fridge wbm35 all lights keep flashing on front sayng the door is open when its not. then the fridge defrosts
if motor makes strange noise intermittently, then a bearing has probably broken in the motor.
time for a new fride as it will cost more to repair.
mine lasted 7 years then did this.
Apr 09, 2008 | Refrigerators
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
supertechks
Nov 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
778 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
