SMOKE CAME FROM IGNITION SWITH AREA WHEN ATTEMPT TO START
I have the exact make, model, year in the repair shop right now with the same symptoms. Horrible screeching noise after starting the vehicle, and smoke coming from the ignition area. Most likely it is a short in the ignition switch. It could have also affected the starter module but I would start with the ignition switch.
SOURCE: Mazda 626
Hi Janieanip01,
Again we need more imfo....Is the vehicle injection?....If it is you'll have to wait until the fuel rail is re-pressurised before it will start....Crank it for about ten seconds at a time so as not to burn out the starter motor....It may be that the vehicle didn't run out of fuel but instead the pump may have given in....and when did you last replace the fuel fiter?
Regards Johngee10
SOURCE: changing the tail light bulbs on a 2000 mazda 626
The Tail Lights Are Accessed From The Inside Of The Trunk There Will Either Be A Panel Immediately Behind Where The Light Is Or Carpet. Remove It And It Will Give You Access To The Rear Of The Bolts Just Grab Twist And Pull And The Light Will Come Out.
SOURCE: white smoke on start up on 1998 mazda 626
Hi
Lots of things to check
?Leaking head gasket
Does it use brake fluid
Start engine only fo a few seconds, shut down, remove all spark plugs to see which ones are fouled
SOURCE: How to Replace a Fuel pump on a 2000 Mazda 626
yes it isn't that much if you buy them.they slide inside the coupler and release the line.
Testimonial: "Thank you didn't know if there was a tool for this."
SOURCE: 2000 mazda 626 wont start,is turning over,fuel
if you have spark at the plugs you need to check fuel pressure at reed valve on fuel rail,you will need at least 55psi to fire injectors,
