Question about RCA R61WH76 61" HDTV
Rca 61" televison comes on for a few mins, get turns off
Rca 61" model num R61WH76 chassis num ITC222A when first turned of tv, the picture is great ..after about 10 or so mins, a line will show up and i can still hear sound then the television will shurt off..
  • ncfirefighte Dec 04, 2008
    even tho when the line shows up, the rest of the tv is black?
  • RCA Master
  • 5,568 Answers
Sounds a lot like a thermal effect.
Buy a can (or maybe two) of freeze spray from an electronics supply company; figure on $5-6 per can.
Open the back of your set and look for a board with larger components on it and fewer small parts; this should be the power supply board. Either enlist a helper or (I prefer) use a mirror so you can see the screen. When the streak appears, hustle behind the set and spray selectively individual components on that board. If you can influence the line, repeat the treatment in a smaller area until you are fairly sure which one is temperature sensitive.
If the component is marked with text, record it. If it is color-coded right down the colors starting from the end closest to the first band.
If you don't want to learn a new skill, namely soldering, you could remove the board and bring it to a repair shop and let them know what to replace.
If you don't find anything sensitive on that board, the problem is going to cost more. You will have to repeat the same procedure using the spray on other boards until you have isolated the trouble area. If you can't single out a specific component, it will have to be sent to one of those 'factory authorised' repair places since failures of parts on the main board will have to be sorted out and then the board will have to be tested in operation and only that kind of repair facility will have the right hardware to do it.
Posted on Dec 04, 2008
  • Steve Allison
    Steve Allison Dec 04, 2008
    If the line is synchronous, then the problem is more likely to be on the main board than in the power supply but you might want to still start there (in the PS) since the component count is smaller there but because of the delayed nature of the appearance of the line, it must still be related to a component warming up.
I have a rca HDTV model R61WH76 after being on for about 15 mins or so I will lose the picture but will stell be able to hear the program. I cleaned out all the dust bunnies etc. to see if this would
I haven't found a video for a 61" model but if your tv is a rear projection tv I suspect that your problem may be similar to this 52" model..
There are other troubleshooting videos on youtube too.
Even if your problem isn't the same you should get some idea of what may be involved.
Sep 26, 2014 | RCA R61WH76 61" HDTV
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
Convergence off all 3 colors showing cannot adjust.
Replace the convergence power board the PSDF240 ITC222A convergence power board is available from www.tvcircuitboards.com under the rCA circuit boards.
Jul 29, 2011 | RCA R61WH76 61" HDTV
3 color curved band lines on my RCA tv.
Ur convergence is dead.U must know how to do soldering to fix this problems?Must replaced 2 STK convergence ICS,and some or all it resistors too.Tries websites Tv repair World.com,Tvrepairkits.com to do the reapair it ur self.The shop will cost U $300 for parts and labors.
Mar 20, 2010 | RCA R61WH76 61" HDTV
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Jul 02, 2009 | RCA R61WH76 61" HDTV
RCA model R61WH76 Chasis itc222 has 3 color curved band lines on
Your model doesnt have convergence ICs. You can get the replacement parts and free instructions on how to do the repair at the following link, just click on the contact us link on the lower left hand side of the website and tell them the model number and chassis they respond quickly.
http://servicemanuals.vstore.ca/
Apr 11, 2009 | RCA R61WH76 61" HDTV
RCA model: r61wh76 chasis: itc222a tv will not completely power up green light on power button on tv will turn on for about 10 sec but there is no picture or sound
These units have a problem with bad connections on the flyback transformer.. Usually, soldering the transformer will fix this problem. Please take time to rate this response. If I can be of further assistance, let me know
Dec 09, 2008 | Televison & Video
RCA R61WH76 61" HDTV Logo
204 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
