Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Panasonic PT43LC14 blinking green light on power button
Howdy all,
The unit powered itself off, now will not power up, just get the blinking green light on the power button; no other indicator lights are visible. Purchased the unit in Nov 2004 and have replaced the lamp unit one time. I'd like to only replace the bulb this time around, however, am having difficulty finding a quality source, suggestions welcome.
With the symptoms mentioned, will a bad lamp prevent power up? or is there another item I should check, perhaps the ballast?
Thank you for taking a moment.
  • Panasonic Master
  • 5,138 Answers
Check your FAN if fan does not work Lamp will not come on ,also Lamps only last 5,000 up to 8,000 hours so every hour that set plays the lamp timer is counting .Go to E-Bay you can find lamps 99.00
Posted on Dec 04, 2008
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Panasonic PT43LC14, blinking green light on the power button
Depends on how much tv you watch, lamps burn out after anywhere from 5,000 up to 8,000 hours also you xould have a bad fan if fan does not work lamp will not come on.
Panasonic pt43lc14 lamp blinking yellow
Lamp, Ballast or power supply are first things to inspect.
May 04, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Dec 03, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
478 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
