Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Replaced Glow Bar still no glow over will not work
I replaced the Glow Bar in my gas frigidaire oven because the oven would not start. The digital display would indicate the oven was on and we sat the temp to 350 then it drops to 100 the oven does not start and then the display goes blank. I replaced the glow bar as I was told that was the likely issue. I put the new one in then tested the oven and got the same result as I was getting with the old glow bar. I took the bottom cover off to see if the bar would even glow but there is nothing the glow bar does not heat up. I then checked to see if my wire connections were good and they appear to be fine. What could the issue be if the glow bar does not heat up and the oven does not start?
  • 1 more comment
  • d_niesen Dec 05, 2008
    Thanks for the help you confirmed what the repair man told me today. I decided to let a pro do the repair after I replaced the glow bar for no reason.
    Thanks for the reply it confirms what the repair man told me today. I decided to let a pro do the repair after spending $80.00 for a new glow bar for no reason.
    Novelist:
  • 157 Answers
Partial clarification: Is this your oven?
If so, just let the other experts know its model number is FEF326FS which could help in finding more solutions.
Try this:
  1. Power down the range and pull the bake element partway out of the oven cavity, usually by removing 2 screws.
  2. Connect your 240V bulb (more directions about the 240v bulb, where to buy and how to use it in testing. If you’re not comfortable dealing with 240V, though, all the usual disclaimers apply - call a technician!) to the element terminals, being sure they aren’t touching the cabinet, and power back up.
  3. Turn the oven to ‘bake’ and watch that bulb. Light: open bake element. No light: control or wiring problems.
If there’s no voltage to the bake element, you might want to power down and remove the range back panel, looking for burnt wires. If there doesn’t seem to be any wiring damage, I'd probably recommend you call a pro.
In most cases, you’ll find either a burnt terminal (replace only with high temp nickel plated ones) or an open element, and either of these are well within the capabilities of a handy homeowner.
Posted on Dec 04, 2008
    Scholar:
  • 81 Answers
Welcome to Fixya.
I'm new here at Fixya
what i think in your problem is the heating contact, i will base on old model oven. the heating contact will release if the oven will come up higher to it setting momentally shut the heater. what new in modern oven, it is digitally operated and not in manual operation. that in the same operation. your heating premature release when it come to higher temp. it is defective already.
and also your power would also matter. try to check if the power system of the oven is direct line to the circuit breaker and no additional load in that circuit breaker.
and post additional comment for additional findings. regarding what i mention above.
    Sergeant:
  • 229 Answers
I don't think the glow bar is the issue by the way the temperature drops then display goes blank etc. the gas ignitor switch in combination with the thermostat are probably the issue. I suggest you have thw whole ignition assy tested and replaced along with the thermostat. Remember electric ovens have some room for error - gas ovens have absolutely no room for error. A slight mistake could be disaster. Good Luck
    Master:
  • 474 Answers
It an electronic problem with the chip/circuit board that controls the temperature and settings.
How old is it? It may be covered under warranty, call and find out, If you didnt get an extended warranty then its probably only got the Manufacturers warranty which is typically 1 year from date of purchase but may be as many as 3, just depends on manufacturer.
Kenmore Oven
I am sure you will just have to replace the oven igniter (glow bar) These will crack and not let any power through the oven valve.
Nov 27, 2013 | Magic Chef Ovens
My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Jul 18, 2011 | Frigidaire Ovens
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
Jul 14, 2011 | Magic Chef Ovens
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
Frigidaire oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 23, 2010 | Frigidaire Ovens
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Glow bar??
it sounds to me like you are on the right tract yes you can change this item pretty easily after you remove the covers it just plugs in just follow your wires and do not touch the new glow bar with bare hands use a clean rubber glove like doctors wear to hold it (the oils on your hand will cause it to go bad faster.although rule of thumb is to replace the glow bar and gas valve at the same time you may get lucky and fix the problem with just the glow bar.after you replace the bar (if it does not work the problem would be the gas valve>NOT RECOMMENDED TO DO IF YOU HAVE NO MECHANICAL KNOWLEDGE
LET ME KNOW HOW IT TURNS OUT FOR YA.YOU CAN EMAIL ME DIRECT AT FIXITRIGHT1@YAHOO.COM I HOPE THIS HELPS YA
BILL
Jan 06, 2009 | Ovens
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
42 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
