I need parts for a Kyocera KM4530 that was vandalized in a break-in. Hopper waste receptible and LED panel parts....I have downloaded a manual and need a source for the parts.
  • Trunk monkey Dec 04, 2008
    Actually this is a copy machine
    Genius:
  • 2,120 Answers
You will have to contact a KYOCERA-MITA or COPYSTAR dealer to get parts.
Posted on Dec 04, 2008
I have a Kyocera KM-5530. It prints light in some areas. There is good transfer to the drum, but just not to the paper. New corona wires, new main high voltage board, new developer, and toner. Anyone know...
This would indicate that you are having a transfer problem or the Paper is very damp. Have you changed the transfer corona wire?
Also check the drop down mechanism that holds the transfer unis. Mechanichaly if it is not in the correct position when in the locked position this can cause the problem that you are experiencing.
Sep 26, 2013 | Kyocera Mita Mita Km4530 Km5530 Compatible...
Error 3600 en kyocera km1820
Is it a C code?
The service manual only shows one code 3600:
U03600:
Confidential polling reception was interrupted because of a mismatch in specified confidential box No. Or, an interoffice subaddress-based bulletin board reception was interrupted because of a mismatch in the specified subaddress confidential box number.
This regards fax system (k)
Jan 28, 2013 | Kyocera Copystar CS-1820 Black and White...
Receiving the message error 8 when I turn the coffee maker on. I turned the switch off for 10 seconds like the manual said and it still appears.
I just fixed mine, it was part of the hopper system. If part of the mechanism is jammed it will flag a error code 8. The part that broke was the little black hopper unit that swings to allow the coffee ground to go down the hopper, it appears that there is a defect in the swing cover as this stainless mechanical spring will break and cause for the hopper to not move properly. What happens is when the spring breaks it caused for the hopper guide to come out of the slot and jambs, when it jambs the unit knows that it is not completing it hopper cycle and flags an error code, in this case #8. The only thing you need to do is put the hopper guide back in its slot and that's it, the only problem is it will take multiple efforts to align the cover but I found that you can fish your hand through the tray opening and guide it into place.
Sep 24, 2011 | Thermador BICM24CS Espresso Machine &...
Self test says 'check waste toner box'
It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
May 21, 2010 | Kyocera FS-C5030N Led Printer
Waste toner receptical problem
The waste ink absorber is inside under the printer, you need a shop to replace them and reset the counter.
Jul 15, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer wants toner but toner hopper is full
Did you remember to take the tape off of the cartridge when you installed it?
Jan 18, 2009 | Kyocera FS-2000D Laser Printer
Emptying waste tone cartridge
You need to replace the waste toner bottle (packaged with a new toner cartridge) you can't just empty it. There is a photo sensor that "reads" through a window of the waste bottle. The sensor could be dirty. Clean the slits with a q-tip.
Oct 01, 2008 | Kyocera Ai3010 Copier
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
Aug 25, 2008 | Kyocera FS-720 Laser Printer
41 people viewed this question
jasbo
jasbo
