Question about Kodak EasyShare C613 Digital Camera
Shuts itself off but lens won't retract
Tried new batteries but can only take 5 photos and screen goes black and lens stays out. I don't know if it's on or off. Press button and nothing happens!
  • 1 more comment
  • ravenhurs743 Dec 03, 2008
    Thanks....I've been using the SD card for a few months and I cleared it, so that should be OK...but...I can't do anything with the camera because the screen stays dark...won"t start (or stop....don't know if it's still on or not)..nothing happens when I press anything! The lens remains out.
    I've tried 3 changes of batteries and that works...for 5 times only, then it does the same thing!
    Very frustrating!
  • ravenhurs743 Dec 04, 2008
    NOTHING will show up on the screen! It goes on for about 3 seconds and then right off AND DARK AGAIN....so there is no way I can get to see menu or anything!
    THANKS FOR TRYING....I LIKE THE "THROW IT AGAINST THE WALL" IDEA!!!!
    Novelist:
  • 170 Answers
Have you initialized the SD card? Go to the set-up menu and initialize the card. Also check for a timed-shut-off option.
Posted on Dec 03, 2008
  • Arthur Aldrich
    Arthur Aldrich Dec 04, 2008
    Remove and re-insert the batteries (polarity OK?) Remove the card. Go to the set-up menu, usually accessed through a dial and select "OK" button in the center. There are several menus built into the camera, which should show up on the screen.
    If you can see a menu, scroll through the selections. The camera is either timing itself out to save batteries, or going into some undesirable mode. My Nikon Coolpix does the same.
    Try to restore default settings. Power down, remove and re-insert the batteries, insert the card and restart,
    Are you using photo-grade batteries and not CVS alkaline?
  • Arthur Aldrich
    That's frustrating as hell. I would have either returned the camera under warrantee or thrown it against the wall. The problem is, the repair costs more than a new and hopefully better camera. Stumped on this one. My Nikon requires me to remove and replace the batteries to clear the camera. When I reinsert batteries and reinsert the card, it works OK.
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
The camera shuts down soon after starting. Turn camera on green light flashes. Screen says reading internal or memory card. Reset time date excetra. Screen goes black. Lens does not retract.
have same camera haen t had that prob sound s like weak batteries go into menu an dsee what its set at and reprogram it to what you want mine never came with the docking station try withou tand new batteries i use rechargable batteries with nicad batteries holds a charge longer
Aug 10, 2009 | Kodak EasyShare DX4330 Digital Camera
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
Jun 03, 2009 | Olympus FE-170 Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Screen goes black and camera shuts off
Are you using lithium batteries?
All Kodak cameras seem to have issues with alkaline batteries.
Although lithiums cost more, they work well and provide better value and performance than alkaline batteries.
Mar 17, 2008 | Kodak EasyShare C613 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
I think my camera's stuck
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
May 16, 2007 | Pentax Optio M10 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
100 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
