Question about Toshiba Qosmio G15-AV501 Notebook
Need motherboard for qosmio laptop. do I have to replace w/same
I would like to have a SATA hdd in the toshiba qosmio. The current motherboard only supports ATA? Also Do I have to put 2 hdd in it. Mine Crashed.
  • Richard O
    Richard O May 11, 2010
    So your current one is PATA right? and you would like to swap over to SATA?
They make an ata to sata conversion cable that you can buy, look on the boxes of the hdd's most of them come with the converter that you need
Posted on Jul 21, 2009
How to bypass boot password for Toshiba qosmio f750
This is a hdd password that is encrypted and stored within the firmware of the hdd. Without it the hdd is not useable. Purchase a new hdd and avoid using another hdd password.
Apr 13, 2016 | Toshiba Computers & Internet
When i open my laptop only Q DISPLAY IN SCREEN HANG UP
Does the hard drive sound like it is spinning.
Did you try to go into the Bios setup?
Jul 27, 2009 | Toshiba Qosmio G25-AV513 Notebook
SATA hard disc compatibility
Actually, there are two good reasons not to swap that drive into the new laptop,
First, you never want to boot from or install software to a drive you're trying to recover as everything you do to/with the drive runs the risk of causing further damage.
Second even if it weren't for the damage, you simply aren't likely to have the right drivers unless both laptops are the exact same model.
My suggestion is just get the new laptop you want, then attach the damaged drive with the enclosure to the new laptop then run your recovery software. If that doesn't work, you will likely need the help of a Pro.
Try Armor-IT Data Recovery, they are listed in the FixYa database and service clients from all over North and South America.
Hope this helps FixYa,
Chris
May 19, 2009 | Computers & Internet
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Finding Sata drivers
Ok, let me see if I've got this right, you want to replace vista? but you need the SATA drivers? To do a dual boot, you usually need to install XP first, and Vista second. As for the SATA drivers, if the XP cd boots up and allows you to edit the partitions, then the SATA driver is already integrated. And here is the download page for your laptop:
Qosmio® F45-AV410
Mar 26, 2009 | Toshiba Qosmio F45-AV410 Notebook
BSOD - NV4_disp.dll - Toshiba Qosmio G10-133
Re-install Windows, at the start ofthe installation, delete the partition, the create a new partition, the do a full NTFS format.
Mar 17, 2009 | Toshiba Qosmio G10-133 Notebook
Toshiba Motherboard and Harddrive
No you can't replace the ata m/board but you can upgrade your hdd's up to 160gb in ATA
Dec 08, 2008 | Computers & Internet
TOSHIBA HDD
I would suggest running linux based GParted live cd. Under linux you can alter the sizes of partitions and configure the partitions and format in NTFS/Fat32/
If you want to try
click on the Download the latest version
From Tuxfamily : http,
gparted-livecd-0.3.4-11.iso
Mar 23, 2008 | Toshiba Satellite P105-S6104 Notebook
Flashing Toshiba satellite 1800-S204
Hi
You query did not give any clues abt the PC/Motherboard and its BIOS revision.
That said if the PC/BIOS will not "see" the HDD then its is unlikely a cause of a virus.
Some old motherboards can't recognise a HDD if its size is more than 137GB. Some older motherboard also require than you set the HDD jumper correctly (Master or Slave).
At this stage, i am assuming the HDD in question is PATA or IDE (Old Spec). If the HDD is SATA (New Spec), then you will need a SATA port to connect the HDD. Ensure not to use both "old" molex power connector and "newer" SATA power connector together.
If the HDD is SATAII but the SATA spec for your motherboard is SATAI (initial spec), some motherboards and SATAII drives require that you jumper the HDD to allow it to work at the lower SATA speed.
If none of the above points apply try upgrading your system BIOS of the latest version. Also review the mortarboard's manual for more info.
Regards
Mike
Mar 23, 2008 | Toshiba Satellite 1805-S204 Notebook
Computers & Internet Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
