How do you login to the 3100 modem to configure it in bridged mode
    Master:
  • 474 Answers
Is it a modem or router? And is it yours or a cable providers.
If its the later, then most likely you wont be able to get into it as they are configured for that company and they control the settings remotely from the service provider. You would have to call them to configure it as they have it locked.
If its yours, some manufacturers put the default login and password on the bottom and you have to IP into it. ( put the units IP address into your Internet explorer bar, just like an address. This i the same way you configure wireless routers like linksys.
Hope this helps, let me know if you need more help.
Posted on Dec 03, 2008
Configure dpc3000 for bridge mode
GO WAN OPTION AND EDIT THIS OPTION AND SELECT BRIDGE OPTION AND TRY
May 31, 2012 | Cisco DOCSIS 3.0 DPC3000 Cable Modem...
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Just got wpn824 and having problrms with pppoe login and pass. Using att dsl ...but that login isn't working
You'll need to set your DSL modem up for "bridge mode". Right now it's acting as a router as well and that's keeping your new router from making the connection. In bridge mode, the modem acts only as a modem to connect to AT&T. Then your router will provide your login information and your computers will connect through it correctly.
You don't give your modem model so I can't give you any specific directions. A Google search for "bridge mode" and your modem's make and model should turn up the information you need. Or you can call AT&T's technical support number and ask them how to configure your modem. (Sometimes these big ISPs aren't too keen on helping you, though. They'd rather supply you with a wireless router/modem at an extra charge.)
Hope this has helped. Thanks for using Fixya!
Feb 15, 2010 | NetGear RangeMax WPN824 Router
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Bridge mode
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Jan 31, 2009 | Westell Wirespeed VersaLink...
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
PRESTIGE 841 & NETGEAR WIRELESS ROUTER
i think there is no need to do bridge mode.
all u need to do is to login to your router and then to clone mac address.
that should fix it and if not then just call your ISP (internet provider).
and ask them to register your mac address.
that should fix your issue.
cheers
Sep 03, 2008 | Zyxel Prestige 841 (91-004-226010) Modem
How do i configure my dlink 302g modem to my new ISP's settings?
Hi Nitangel
Before proceeding with modem installation you need to gather your connection details from your Internet Provider. You will need to know or find out the following information about your new ADSL connection from your Internet Service Provider:
Connection Type:
PPPoE
PPPoA
Bridge RFC1483
Default IP address: 10.1.1.1 (USB 10.1.1.2)
Username: admin
Password: admin
· Username / password (PPP connections only)
· IP address / Subnet Mask / Default Gateway (Bridge connections only)
· DNS IP Addresses (optional)
To set up, log into the modem using your WEB browser: type http://10.1.1.1 in the address bar and press Enter.
Enter username 'admin' and
password 'admin' (default setting).
Go to Quick Configuration page.
Set Refresh Rate to "No Refresh".
If it is a PPPoE or PPPoA CONNECTION:
Select Operation Mode: PPP.
In the Connection Type drop-down menu select PPPoE or PPPoA profile.
Enter username and your password.
Select CHAP under Authentication Type (check with your ISP if not sure).
If it is a BRIDGED RFC1483 CONNECTION:
Select Operation Mode: Bridge. If you do not see "Bridge" options please update your modem's firmware at http://www.dlink.com.au/tech/
Select LLC or VC Mux as suggested by your provider.
Make sure your VPI/VCI is set according to your ISP requirements:
Click on "Save & Reboot" to save settings.
Then give modem a minute or two to reboot and reconnect. Restart your computer and you should be able to access the Internet.
You do not have to run any login client on your computer or router because your modem logs to your ISP automatically.
Hope this information helps if I can help further let me know.
Jun 17, 2008 | Computers & Internet
Ativa router and at&t
there is a link in the motorola UI that allows it to be put in "bridged mode" so you can configure the router. however, before you do this, i suggest you have to make the motorola (is it 2100?) modem work with your computer, connect this modem to your computer using ethernet connection, access the UI (192.168.1.254), type your user id & password in the login page, then connect. make sure that you are able to connect to the internet. then access the UI again, click on "advanced" choose PPP location. in the PPP location page, click on bridged mode, that will restart the modem automatically, & you will notice the modem's internet light will turn off. then you can connect the ativa router to this modem using manufacturer's instructions. you can now login to the router's page and make the necessary changes.
Apr 20, 2008 | Computers & Internet
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
David Payne
David Payne
