Question about Amana Haier AP125HD Air Conditioner
Heater problem I've been using the heater and as of lately the unit is just blowing out cold air. The temp is pretty low but i lost the manual and i can't figure out how to higher the temp ... I've got the amana AC125hd. Email me at Luckyme162@aol.com or post back here if u can help at all!
  • 734 Answers
This sounds like a Blend Door problem. The problem is that the blend door in the plenum is stuck in the A/C position and will not reposition to allow heat.
There are two possible issues.
1: The Acuator has snapped off (plastic breaks)
2: The Blend Door is broken (plastic hinge broke)
There are related articles to fix both of these conditions
Posted on Dec 04, 2008
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
My cars temp suddenly ran in the red (hot) so i turned the heater on to cool it down and the heater would only blow cold air what could this be?
"ran hot and the heater only blows cold air"
First thing that came to my head reading this is check the coolant level.
Aug 31, 2014 | Cars & Trucks
2007 pontiac vibe heater blowing cold air
The heater hose's going into the passangers compartment through the fire wall are they both hot ? Possible plugged heater core !
Dec 10, 2017 | Cars & Trucks
Heat goes in and out and the temp gauge goes up and down
Your temp sensor has nothing to do with your heater. The temp sensor needs coolant in order to work properly. So first check the coolant level because if it is low your heater will act the way you describe. Once the coolant gets low enough the heater will blow cold. Another possibility is the radiator cap. After the engine has warmed up it expands when it cools down it contracts. As it is contracting if the cap is weak air can be drawn into the system and cause air pockets to form and will cause the same problem
Feb 09, 2013 | 2000 Pontiac Grand Prix
I have a 2002 chevy silverado 5.3L with a v8 engine. My heater is gone out in my truck it only blow cold air.
Check the coolant level first. Low coolant usually affects the heater first. Check you temp gauge and make sure its getting up to temp. Carefully feel both heater hoses where they go thru the fire wall. They should both be about the same. If one is noticably cooler than the other you have a restricton in the heater core and will need to replace it. On some air condition models there is a vacuum operated shut of valve to the heater when the a/c is in use. Your temp selector could be bad in the das or you could have a vacuum operated "shunt door that is not working.
These are pretty much listed in the corrrect order.
Lee
Oct 23, 2010 | 2002 Chevrolet Silverado 1500HD
Temperature gauge fluctuates and the heater blows cold air
Definitely check your fluid level in your radiator. Top it off all the way. I've seen that happen multiple times on cars that were low on anti-freeze. If that doesn't work try replacing your thermostat. It's cheap and the easiest place to start if topping off the fluid doesn't get you fixed up.
Oct 16, 2009 | 1997 Chevrolet Camaro
Heater does not blow hot air, just cool air
You can put a higher temp thermostat and that should help, but it should at least have 170 degree air right now if it was working right. There are two other things you might check for, the diverter door make some sound when you switch from heat to cool and back, I can't tell you for sure if it is a manual, vacumn or electric but that would definitely cause it to blow cold air. There is also a valve which cuts off circulation to the heater core when your not using it. This valve will be in line with the heater hoses going to your heater core. I have seen some that were actually part of the heater core box. I feel pretty sure one of these will be your problem. Also if your car is low on coolant it would not heat properly. Hope this can help you!
Dec 15, 2008 | 2004 Volkswagen Jetta
Heating & Cooling Logo
185 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
