Question about Rolex Day-Date President 118239 Wristwatch
Hi, I have a Rolex Oysterdate watch, and I am having trouble figuring out how to wind the watch. It is a manual watch.
  • Anonymous Dec 12, 2008
    how do i adjust time on my rolex oyster
    Problem Solver:
  • 17 Answers
I should be self-winding. Put it on your wristing and move around.
Posted on Dec 04, 2008
I usually shake my Rolex (Datejust Oyster Perpetual) because it slides to one side, but when I shake it, the second hand sometimes stops. Once I shake it again, it begins to tick again. I have tried...
What's the question? From you description of the troubles you are having I suspect that your watch may on the outside look like a Rolex, but it certainly does not behave like one. I have never had such erratic behavior even with my much cheaper, but authentic Casios.
Sep 26, 2013 | Rolex Watches
Dear Sirs, I have a Rolex Daytona watch new and I have a problem. The hour is delayed too and can not operate for more than a couple of hours. This watch is a gift from a family and can not find the...
This is a self winding watch and should run for 2-3 days when fully wound.
To wind it, wave it gently from side to side for about 200 times.
If you still have problems, speak to Rolex, they should be able to sort out your problem. (see rolex.com).
Feb 22, 2011 | Rolex Daytona 116520 Wrist Watch
I have submariner Rolex watch and when I unscrewed the winding stem where I can manually wind it, I started to wind it and all of a sudden it was like something snapped and there was no more tension when I...
These watches are selfwinding so you should not have to use the crown to wind it up. (Although some watches have this as an alternative).
To wind it up shake it gently from side to side for some minutes and it should start.
No tension on the crown wheel is worrying. If you pull it further out and can adjust the time in position 3 (fully out) and the date (half way out), then it may be that no damage has been done. If you cannot adjust the time, then it looks like a trip to the dealer is required for repair.
Feb 10, 2011 | Rolex Submariner 16618 Wristwatch
Do replica Rolex watches have the insignia stamped on the winding arm
Yes, approximately 95% of Rolex replicas do have Rolex crown stamped on winding crown.
Nov 16, 2010 | Rolex Daytona 116520 Wrist Watch
My rolex datejust watch has stopped working...rolex watches don't operate on batteries right? Why has it stopped ticking?
mcdevito75 here, The answer is no, Rolex watches do not operate with a battery. Most Rolex watches are Automatic winding with the motion of your wrist / arm. Of course if you leave your Rolex on the dresser for say 30 hours, it will run down, simply hold the watch in your hand and with a gentle rocking motion say from 6--to 12 O'Clock for about 30 seconds, this will give your automatic Rolex an initial wind up, from there you just wear the watch and it will continealy wind itself. You may also have the non automatic Rolex in which case you would have to wind it dailey. If your Rolex will not run at all no matter what you try, Check out the repair service directory here at fixya, bottom of the page click on repair service directory then watches.
Aug 01, 2010 | Watches
I had my Rolex watch serviced 2 years ago By Rolex and now
Either the stem or latch needs to be replaced. It's a common problem for ALL manual wind watches.
Dec 06, 2009 | Rolex Watches
I have rolex datejust that looses time, i do not wear it to bed.
Hi Sggann. You shouldn't need to wear a Rolex automatic watch all the time for it to be kept wound, and you can in any event manually wind it 30 times to top-up the mainspring. You don't say how long you've had the watch, or when or if you've serviced it, but it sounds like it might need a clean and service; this replaces the oils which can thin out over time and effect the timekeeping of the watch, and the watch will be tested to ensure it runs well. Get Rolex to do it, unless you know a capable and accredited watchmaker - it's not cheap (around £250), but then again the watches cost a lot! All the best; Eagle58
Apr 20, 2009 | Rolex Explorer II 16570 Wrist Watch
Rolex watch
if your watc is automatic or self winding,you need to use your watch at least 12hours a day,to set the time , wind the crown counter clock wise,until the crown lose then full the crown to set the time,after setting the time fush the crown then wind it clockwise to lock again! thank you !
Aug 26, 2008 | Bulova Watch
Opening woman's rolex
You need to go to a place that sells watch and jewelry supplies, because there is a certain tool for opening a Rolex. I am interested in knowing why you need to open it up though. If this is a Authentic Rolex ALL womans Rolex watches are automatics. Try unscrewing the crown (the part used to set the time ) counter clockwise and then clockwise turn the crown and listen to hear it winding, if it is infact an automatic, wind it 50 times. After winding, push crown in ( it is spring loaded) and screw in clockwise. It should run. If wearing every day you will not have to wind again, if wearing less frequently rewind as specified.
Mar 19, 2008 | Rolex Day-Date President 118238 Wristwatch
Rolex Day-Date President 118239 Wristwatch Logo
307 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
