Question about Whirlpool GH5176XPT microwave Oven
Whirlpool Accubake Microwave Oven 2001 vintage.
How do I change the interior light bulb in the center of the top of the oven. How do you remove? It is pushed into the top void of the oven. How do I access?
  • 706 Answers
Hello jparks739,
Please find a link to an exploded view of you micro as well as details on how it goes together. Note the two screws ( item 31) that hold the cover and lens over the bulb in this document.
Hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Dec 04, 2008
How do I replace the interior light bulb?
What model of microwave oven do you have?
jvm3670sf02, you need to remove the exhaust plate above the door. The bulb will be in a pocket to the right of center. Usually there are snap tabs holding the cover in place on top, then rotate down.
Jan 02, 2016 | Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Dec 02, 2009 | Microwave Ovens
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Whirlpool GH5176XPT microwave Oven Logo
745 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
