Question about Mitsubishi VS-60609 60" Rear Projection Television
Menu comes up, sound comes up, but no picture
Everything works-I even get the menu up without a problem, but there is no picture! From the back you can see that there is something going on, but all there is is a blank screen.
Any easy way to fix this?
  • wings_it
    wings_it May 11, 2010
    something is going on?? can you describe please.
    Did you try with a dvd player or any other source?
    Do you have sound?
5 Suggested Answers
  • 979 Answers
SOURCE: MITSUBISHI vs-7083
What is your source? Antenna, cable, or satellite?
accordianman
Posted on Feb 22, 2008
SOURCE: Mitsu vs60603 menu ?
Reset doesnt work. Power cord plugged in, green power/timer light on but no sound or pic using the front panel or remote?? Help???
Posted on Aug 19, 2008
Russmann
  • 203 Answers
SOURCE: sound but no picture, menu looks bowed/hourglass screen
This is a common problem on projection sets and if you have someone carefully resolder the pins of the convergence chips, it will probably solve your problem. If you continue to use the set, the amps will fail and leave a dead set condition. What needs to be done is to disconnect the power, remove rear cover, loosen all snug wiring making sure to mark any wires that you disconnect, remove screws holding chassis in and undo plastic hooks at front of chassis, access bottom of circuit boards and with low wattage soldering iron resolder convergence amps, reinstall chassis and rehook all plugs in original places especially ground wires and high voltage leads, and test. If the soldering iron is too powerful it will damage the chips, also, be sure each solder joint is clean and not touching the one next to it or you will fry circuitry. Hope this helps. Russmann.
Posted on Jan 28, 2009
MikeMaierTV
  • 206 Answers
SOURCE: blank screen no sound,but all menu options show on
This was a common problem with this set there is a repair and a bypass posted on my website www.competition-tv.com simply click the link on the first page marked Mits bypass
Posted on Dec 18, 2009
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
Dish menu but no picture or sound
Try holding the power button in on the receiver until the picture goes away then turn it aloose it will reboot and your sound will usually come back. If you had rather and can get to it unplugging it from the electric outlet, the receiver, does the same thing.
Oct 21, 2009 | Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
TV won't turn on after a repair
you changed all the eprom info but didn`t "save to ram" before un-plugging ac cord, you will have to call a tech and be sure to advise him what you have done so the tech will be sure to bring service manual, info will have to all be re-entered, video-tek
Jun 10, 2009 | Samsung HCM5525W 55" Rear Projection...
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Mitsubishi VS-60609 60" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
