I was woundering if my router has gone bad. I have a Linksys BEFSR41 and I cannot log into the config area with 192.168.1.1 I end up getting a page cannot display message any advice
  • 4 Answers
May be your router config your network .u just check out ping your router then router is replay so ok router is working ok it's may be disble https access ..
Posted on Dec 04, 2008
Hello. I am trying to get my NAT open with my linksys BEFSR41 V4.3
You are trying to open the NAT on the router.
For this you will need to reduce the MTU settings on the router
to 1365. Disable the UPnP on the router.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Sep 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Befsr41 ports will not light up
Please try to reset your router by holding the reset button for 30 secs. After 30 secs release the reset button. Than take the power cable out of your router and plug it back in after 30 secs. If the lights are stable than its ok, else your router has gone bad.
**If this works please rate else let me know in case of further help.**
Jun 22, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant get configuration to complete on befsr41 router
Press the reset button on the router for at least 30 seconds. release it. Unplug the power to the router . wait for 10 seconds and plug it back in. Wait for 1 minute and try to set up your router.
If you are having trouble setting up your router with the CD, then you can set up your router without CD also. You can do it manually.
First make sure that your computer is online directly through the modem without the router.
If that is working then you can connect the computer and the modem to the router. Open the set up page of the router and change the settings of the router according to the settings of the Internet service provider
Click here for more information about router set up
Feb 16, 2010 | Linksys EtherFast Cable/DSL Router
I am trying to reset the default log in on linksys befsr41 router
If you want to reset the router to its default log in , the only way to do that is to manually reset the router by pressing the reset button of the router for 10 seconds while power is ON and after that the log in of the router will be back to its default log in the username is blank and password is admin
Nov 25, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
AOL Broadband Cable
The following routers are the only models that support the AOL Broadband Cable service. Note: All Linksys routers support AOL DSL connections due to the standard PPPoE login and authentication connection type used with that service. Please be sure to check the version number of your router (which can be found on the underside label). Only the specific models and versions listed here are supported by AOL Cable: * BEFW11S4 * BEFW11S4 v2, v3, and v3.2 * BEFSR41 * BEFSR41 v2 * BEFSR11 * BEFSRU31 * BEFSR81 * BEFSR81 v2 * HPRO200 (Available from AOL only at this time) You must Enable the "AOL Parental Controls" option located in the Security tab of the web-based Setup utility pages of these routers in order to get a connection using AOL Cable. You may access the utility by visiting http://192.168.1.1 in a web browser and by logging in using the router's password (by default, the password is admin).
Feb 16, 2006 | Linksys HomeLink Phoneline (HPRO200)...
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
