Question about HP Officejet 5610 All-In-One InkJet Printer
Communication error - error 388
My fax wont go thru and i've tried several times. i've called the other fax and i hear the beeeep-beep-beeping on the other side so i know their fax is working.
  • Anonymous Dec 30, 2008
    comm error 388. trying to fax to hotel in mexico for work, but keep getting that error. very frustrating!
    Scholar:
  • 97 Answers
Hi valmohr,
Please clcik on following link and follwo the document and tried to turn off the ECM on your printer, which would resolve this issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01345512&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Posted on Jan 20, 2009
Computer boots up and gives beeping noise, and monitor fails to detect computer.
Two components inside your computer is causing thins beeping sound. If the beeping like this, beeeep beeeep beeeep beeeep , then you have a problem with your memory card, clean your memory card and try to boot it again. If this doesent work, replace your memory card. If the beeping sound goes, beeeep beeeep bip bip. Then you have a problem with your video card. Try to clean it first, then reboot. If this has no effect, repace your video card... I hope this would have a positive effect on your computer. Have a nice day my friend.
Aug 20, 2011 | CyberPower C Gamer Xtreme 5212 Desktop -...
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
Hello, I just purchased a GE SImon XT system with two motion detectors and a smoke/temperature increase detector. I live in a very small house and don't need more. Everything is hooked up and works...
Clarence,
If the problem is the Communication Failure, try to reprogram the Home Security System. The codes that you need are indicated in the user's manual. If reprogramming the Simon would not resolve the problem, try to get the master code from the manufacturer.
Reprogramming the device should resolves the issue.
Aug 25, 2009 | GE Security Simon 3 Wireless Home Security...
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Two beeps long
You DIMM(RAM) cards are loose. You will need to take them out and reseat them into their place so that the system will let you through. Tow beeps indicate memory testing failure so thats all you need to do.
May 10, 2009 | Asrock M266 G-SALM Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Feb 08, 2008 | HP Officejet 9110 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
872 people viewed this question
Ben Johnson
