Question about Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 Pink vertical lines
Hi, I was given the above TV by a friend the other night because it was diagnosed with a bad optical block and he chose to replace the TV instead of repairing it. I had to transport it face down when I moved it from his home to mine. When I plugged it in and powered it up it played perfectly all day. However, when I turned it back on later on, the screen was filled with pink vertical lines about a half inch wide and all across the TV screen. If the optical block was bad, why did the TV work fine for a while? I'm thinking a bad connection or a loose circuit board may be the problem. Do you have any suggestions on where to start and are there any common problems with these TVs that have the same issues as I have described and if so, what was the repair? Thanks
    Sergeant:
    Champion:
  • 318 Answers
Dear, the circuit for controlling speed is affected and that circuit is composed of passive componets inductor, resistor and capacitors. the only possibilities is to check loose connections a round the line transformer and around the vertical section. also check and measure the values of your electrolitic capacitors, cause these also change values when wax finishes in side them.
check that and contact me for the out come.
thanks for asking fixya.
okay.
Posted on Jan 16, 2010
MY SONY KDF E 55A20 REAR PROJECTION TV HAS THIN RED VERTICAL LINES ON THE RIGHT SIDE..HOW DO I FIX THAT
You need to replace the optical block to fix this problem it sounds like one of your LCD chips is burning out and that is why you get this kind of side effect the OPTICAL BLOCK usually runs around $230.00 - $350.00dls plus labor here is a guide if you want to replace it on your own
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | Sony KDF-E55A20 55 in. LCD Television
I have a KDF-55E2000 Sony Grand VVEGA Color Discoloration
Bad news: The issue can only be solved by replacing the optical block for the TV. This was a defect in the design of this TV. Replacing this part is very expensive (over $1000) and time consuming (need to take whole TV apart).
Good news: Sony extended the warranty for the optical block for this model. They are covering the cost of parts and labor for this TV. Contact Sony to have them refer you to a authorized service center near you.
Oct 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 26, 2017 | Sony KDF-E55A20 55 in. LCD Television
Red line across screen on a Sony kdf42e2000
OH YES, IS THE OPTICAL UNIT BLOCK BAD, THE PART # IS A-1212387-A
Nov 25, 2008 | Sony KDF-E55A20 55 in. LCD Television
How do I get to the bulb?
You can buy Original Lamp for your Sony KDF-E55A20 from Sony Accessories (Official Website of Sony) by entering model number as above in search box.
For your information, Lamp (bulb) part number is ...
A1085447A* LAMP BLOCK ASSY XL-2200U and price is approx $200
Thank you.
Oct 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
SONY KDF-E55A20
No it sounds like the thermal fuse.
Apr 14, 2008 | Sony KDF-E55A20 55 in. LCD Television
The lamp?
This unit does not contain any CRT's. This unit uses a Optical Block Assembly to produce images on the screen. There is a lamp that is user replaceable for this model (KDF-E55A20). You can find the lamp for this model listed below.
Sony KDF-E55A20 Lamp Original Replacement
Apr 11, 2008 | Sony KDF-E55A20 55 in. LCD Television
PINK SPOTS, VERTICAL COLORED LINES ON INPUTS, TV SHUTTING OFF
I had the same exact problem I found an article on the internet
(http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock)-I took my tv to get diagnosed, thay said it required an optical block.I then phoned sony & then faxed the estimate & the bill of sale to them & 3 weeks later they phoned me with a offer-they offered me another tv ( 46 inch-retails for $2400) for $1150 plus an addition 2 years warranty on top of the 1 year & thats what I am watching now.
Apr 11, 2008 | Sony XL-2100U Projector Lamp for...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
192 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
