Back to:
Tags:
BenQ FP567s  15
Screen blacking in and out (by 4 users)
posted by esdee on Feb 05, 2007
My screen is blacking in and out. The green monitor light also flickers on and off as the monitor briefly shows the screen. Have tried it on a diff pc with same results. In fact just plugging the monitor to electricity results in the green monitor light flashin on and off. Monitor is only 3 years old so I am surprised if it the monitor that has gone. Any suggestions please ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by mctelng07, posted on Aug 08, 2008
The monitor screen flickers and the power tuning on and off.
Tony
Comment by jidamica, posted on Apr 20, 2008
I am having the black in an out problem also. It happens each time I turn the computer on. I turn the green light on and off, up to 20 or so times, then eventually get in. Most annoying!
Comment by karimmkd, posted on Dec 13, 2007
My Benq fp567s switch on and off, each times I turn on my pc. The blue light turn to yellow without stopping. There is not time for the image on my screen to appear when it switch repeatedly on and off, it appears like some slow flashes. PLease help me. My monitor is only 2 years old.
Best Solution
posted on Feb 06, 2007
Helpful (85)
tomj23
Rank:Guru Guru
Rating: 86%, 1553 votes
Hi Esdee,
Don't be too surprised if the monitor is having problems. The fact that it does the same thing on another PC is pretty good proof that is in fact the monitor.
As far as what is going on the green power LED going on and off in conjunction with the blackouts indicates a power problem to me.
- Does wiggling the power cords, plugs cause any change?
- When the screen blacks out shine a flashlight on the screen and look to see if you can see any faint images. If you do then you have a backlight problem.
If none of this works any further troubleshooting really requires some experience working around electronics and high voltage.
Let us know how you want to proceed, as as always please don't forget to rate this posting.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Screen blacking in and out:
I don't want to Accept this solution
Solution #2
posted on Oct 05, 2008
Not Rated (0)
bammbammfran
Rank:Master Master
Rating: 88%, 6 votes
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Thank You!
Solution #3
posted on Jan 31, 2008
Not Rated (0)
knreddy_pc
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have Benque FP567s 4 year old now, i just have image for around 1 second and then i just get a black screen, the power led also goes off, and each time the i hit the power button, the problem repeats. But when I pull the power cord this side & other side many times the monitor works normal , but the proble may repeat in hours or next startup (It was also checked & found there is no problem in power cord or its fitment )
Soln: From above symptoms I suspected some loose connection on PCB of LCD. I have opened the casing. I found one screw is missing out of two, which hold power socket to chassis.
From this I have analyzed that probably due to this screw missing (manufacturing defect), some force of fitting cord into this socket was transferring , especially when removing , fitting back monitor cord into the socket during last 4 years.This might have resulted in ing of PCB or Power socket solder or some weak solder . Due to this, when we move power cord to fro, probably the above problem is disappearing temporarily.
I dismantled the 2PCBs (both boards are interconnected) and inspected. There was no , but I suspect soldering of L563 & power socket connections weak/ suspect able.
I soldered above joints & nearby joints (probably 5 % of total joints on main board).
The problem is solved on 31.01.08. Time taken for analysis : few minutes
Decision for opening by self : 2 days
Duration of repair : 1hr 15 min.
Damage: while opening of external plastic casing, some plastic holders / clamps got broken, probably if casing is required to open next time, it will be easier. This may happen even with a good mechanic.
Care: to be opened in modular way, by plugging off connecters between one module to other. Assy is to be followed in reverse.
Thank You!
Can you Help with these Monitors problems?
BenQ FP567s (Beige) 15" LCD Monitor
Benq FP567s Circuit plz...... one component missing so....
These feature as soon as the monitor is switched on and...
The power light blinking green and the screnn flicking on...
The screen is flashing, not stable and no output from PC
2 Monitors same problem. Wont come on, Standby mode only....
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
