Question about Western Digital (WD3200JS) 320 GB Hard Drive
My WD ebook 320GB stopped working after a series of power surges
It was working fine earlier in the morning and then there were a series of power surges. then my laptop could not read it anymore. i tried to plug it into different usb ports but to no avail, it still wasnt recognised at all by my laptop. unfortunately i dont have any other computers in my house to try it plugging it into. it powers up fine but is not being read. what can be done to recover the data? is there software that can be downloaded to read it? it has over 200GB of data so i need to know what to do?
  • lubuyeb Dec 04, 2008
    my hard disk cannot be read by any pc after power problems,in the computer management disk drivers its there but in my computer its not read,so i cannot see anything on my hard disk,its 1000 GB WD type external,plse help on lubuyeb@yahoo.com
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
Mitsubishi WD 52525 - Blue Screen RBGHV or YPrPb
Try unplugging the TV set from the wall for at least an hour or so.
Aug 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I have an issue with my external hard drive. The model is WD 320GB Mybook. I've checked the power wire and the usb wire and pretty sure that both are working. I don't hear anything from the driver as I...
I have a similar WD 320GB drive - but it is a Passbook. When I first got it, I set it up and it worked fine. Not liking the very short 12" (.3M) cable, I grabbed a nice 6' (2M) version as a replacement.
I began to have read and write errors on the drive galore. I returned the drive and spoke with a tech person at the store about it. It turns out that the cable supplied is "specific" to a degree for the drive. Use of "any old" replacement USB cable would not work reliably. I found later that I had another 6' cable that worked without a problem. The cable is rather thick when compared to some of the others I have and am assuming that it was a quality issue with my first cable that caused the failures.
Result: Use the original cable if possible. Use a good quality cable if the original is not available (experiment with a few if needed). Of course, if the drive just plain stopped working - and it happens - contact Western Digital tech support for help or replacement if it's still under warranty, or bite the bullet and buy a new one.
I hope this helps & good luck!
Feb 25, 2010 | Western Digital My Book Essential 320GB...
I accidentally droppped my brand new 320gb WD Passport now it isn't working it lights up & it has a tick sound then stops spinning...pls help.. :(
Most likely you have damaged the actual harddrive, the ticking sound is NOT A GOOD HARDDRIVE SOUND! Contact western digital and tell them that your NEW harddrive is making this sound out of the box DO NOT MENTION DROPPING IT. They should RMA it as long as you really did just buy it.
Oct 04, 2009 | Western Digital Passport 320GB External...
WD 320 GB ceased spinning
ensure it hasnt damaged and that you didn't passed a magnetic field through it, so that you damaged the sytem files of the hard drive...
Sep 16, 2009 | Western Digital Passport 320GB External...
How do you recover the data (photos) from your ebook if it won't turn on anymore? I have a WD 250 GB ebook and I think it was damaged by a power surge. I can't get it to turn on anymore and I don't know...
It's possible you can open up the outside case, then put the drive into another computer (might have to change some jumpers, then just add it on your IDE ribbon cable), but this is assuming the power surge only fried the case part and didn't get to the drive.
Keep in mind, if you have a warranty on it, this WILL most likely void it:
http://www.overclock.net/other-hardware-mods/213783-removing-hdd-wd-mybook-essential.html
If that doesn't work the only way is to use computer forensics (electron microscopes, etc) and this would cost way more than any photo is worth unless you're loaded.
May 04, 2009 | Western Digital 320GB MyBook External USB...
WD External Hard Drive 320GB Cyclic Error
Windows Delayed write file error
Read this
http://support.microsoft.com/kb/330174
since your talking about the External drives, a lot of reasons makes this happen. if the resolution above link cant help you, then try this:
Make sure that update the driver of your PC hard drive. Usually, this errors appear if your moving from one hard drive brand to another ex: seagate to samsung etc....
updated hard drive driver resolve this.
Make sure the cables are alright. Or at least have the latest service pack. USB drivers causes issues as well. I updated mine and the problem did not crop up anymore. hope this would help.
Feb 22, 2009 | Western Digital Elements powered by WD 320...
Canon PIXMA MPA830 power loss
I had a similar problem after a power surge. But when I left it unplugged for 10 minutes and then plugged it back in it powered up just fine.
May 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ebook 320 external hard drive
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
May 03, 2008 | Western Digital 320GB MyBook External USB...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
382 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
