Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi rear projection tv
When the tv comes on the picture shakes or there are lines that span the picture that vibrate. After the tv warms up, it all stops and is ok. What is causing this? Thanks
    Novelist:
  • 192 Answers
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Posted on Feb 11, 2007
Mitsubishi WD-52525 52" Rear Projection HDTV popped, bad picture and vibrates
The pop was a high voltage arc of electricity that blew some vital components on the main circuit board. The unit is of no use now. Repairs are far more than replacing the TV.
Feb 27, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My tv mitsubishi vs-60705 looks great when i first turn it on after it warms up picture starts to shake and gets worse the longer its on. what is overheating to cause this ?
Sounds like you have a swollen cap in your horizontal hold circuit. Look at your board closely, and I am sure you will find one that is bulging on the top. Just replace with the same value.
May 16, 2011 | Mitsubishi VS-60705 60" Rear Projection...
Picture turned to red then picture disappeared. voice can still be heard. lamp light not on.
The projection lamp is dead.The tv projection lamp in the tv now,been in the tv like 1 1/2 or 2 years,The lamp life span is over. Require replacing a new projection lamp.
Aug 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Picture shakes and hass horizontal lines
The chassi will need to be removed and sent to Mitsubishi to be rebuilt.
Mar 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Shaky picture once warms uphorizontal lines stream through it continuisly
there are some capacitors on the signal board that are associated with the pwer supply regulators off the 5 volt and other sources there that need to be replaced
if you have the tools and know how and soldering station you can do the repair your self if not then you might want to contact a servicer in your area
i can get you the cap location numbers if you like
Oct 24, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-60707 60 in. Rear Projection Television
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Oct 26, 2007 | Mitsubishi VS-60707 60" Rear Projection...
On bright screens picture goes to white and shakes
Sounds like a bad crt, also has you set been used to play video games if so this could be a cause for bad crt, weaking tubes
Oct 23, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
247 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
