Question about Armstrong Plumbing
Armsrtong 1/12 horse pump noise
My armstrong pump is making a lot of rattling noise from teh middle bearing area (i have been adding the drops of oil 2 -3 times a season), and it is about 4 years old, pumps the water from my boiler to the rads in the house. could the bearing be shot already ?
I bled air from the rads attached to the system and now the noise is gone from my circulator pump
Posted on Dec 04, 2008
My Lincoln Continental 2000 Model oil light came on engine stopped after 25 feet. would not restart even though oil full. The car started the next day, but had a rattling sound at the top of the motor
Oil light is rather important it goes out if oil pressure is good comes on if oil pressure is low when it comes on damage is expected with continued operation like wearing of main bearings and pistons and cylinders can lead to a engine rebuild
May 30, 2017 | Lincoln Cars & Trucks
How do you fix a engine motor
Caridad, there could be a lot of things making noises from engine, causes could be low on oil, belts/tensioner/water pump bearing, worn internal engine bearings, etc. You will have to have a good Technician diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sounds Like Trouble Quick Guide to Diagnosing Common Engine Noises
See Engine Noise Diagnosis Videos at YouFixCars com
Car Noise Emporium
Jul 22, 2016 | 2008 Lexus IS 250
Oil Gauge Dropping to 5 psi
Hi again Kelea, I'm glad to help!
Kelea, if you do not hear a lot of engine rattling noises then I would say your "Oil Pump" is OK and you need to replace the "OIL SENDING UNIT" which you can buy at Autozone. CAUTION: If you do hear a lot of rattling noises coming from your engine then I'd suggest having someone check the oil pressure. If the oil pressure is low then it could be all kinds of things that can cause low pressures. From engine bearings, to restrictions, to the oil pump itself. I would start with the oil sending unit first and see what your oil pressure looks like. If your oil pressure is good after replacing the sending unit then I'd consider never taking my vehicle back to the shop that told you it was the pump. Hope this helps and have awesome day.
Feb 25, 2013 | 1999 Chevrolet Blazer
Oil pressure drop to 20 lbs lifter start to rattle
20lbs really is not enough to cause the lifters to make noise,the gauge maybe wrong The oil pump screen maybe stopped up,and the rod and main bearings maybe worn.If this was helpful,please rate,thank you.
Jun 13, 2010 | 1999 Chevrolet C1500
Sounds like a bearing going bad where do i look first
a rod bearing makes noise when you are just barely pulling .. it likely will quiet down as you accelerate and decellerate .. you can rev the engine up a bit then let up on the gas just enough to keep that rpm ..a rod bearing will rattle a lot then ... if a thud like noise happens when you are accelerating . then it could be a main bearing .. if the noise is there all the time and sounds like a rattle then its more likely a valve problem .. old oil can cause the lifters to stick and rattle continuously .. if the noise you hear is a squeal then you could have a bad bearing in the idler pully (for fan belt) or alternator .. if thats the case you can put a drop of oil on the bearings one at a time until the squeal goes away .. that will identify which part is going bad .. there are other less likely bearings that can go bad .. like the cam, distributer, air compressor and water pump .. each have their own type noise ..
Oct 23, 2009 | 2003 Chevrolet Monte Carlo
I have an Isuzu Rodeo 3.2 L when the engine is cold, motor sound good oil pressure is between 30 and 55 as it starts to get hotter oil pressure drops and the rocker arms start to rattle. When engine is...
The oil pressure in an engine will naturally drop off as the engine warms up. If the oil pressure is dropping too much it could be cause by several things. I don't know how many miles your engine has on it but the oil pump may be getting weak and may need to be replaced. Worn out cam bearings or crank bearings can also cause low oil pressure. Sounds like your engine may be ready for a rebuild
Jul 16, 2009 | 2002 Isuzu Rodeo
My pump is making a noise that I am trying to get rid of. I added the oil to the top of the pump (is this correct)? I have been trying to get rid of this noise for three days..please help
you should call and contact Bell & Gossett .(847)966-3700 Address: 8200 N. Austin Av. Morton Grove,IL 60053. Ask them that if the part no # 103400 Price $260 fits for your pump Good luck.
Jan 21, 2009 | Armstrong H 67 1PH Bf In Line Circulator...
Hard lifter noise after pulling trailer with Isuzu trooper 3.5L
Sounds like you didn't run the engine in. Check the oil for mangled main bearings.
Jun 14, 2017 | 1998 Isuzu Trooper
Engine vibration at start up
water pump by teh sound of it seal ok but bearing going
Nov 12, 2008 | 2002 Ford SVT Focus
Plumbing Logo
450 people viewed this question
Top Armstrong Plumbing Experts
Paul Carew
Boyet Soriano
Boyet Soriano
Are you an Armstrong Plumbing Expert? Answer questions, earn points and help others
