Question about JVC MX-J900 CD Shelf System
Black and White video output
How could i fix my JVC MX-J..or something which showed a black and white output?
    Problem Solver:
  • 30 Answers
Check your tv system,(PAL,NTSC etc.)same as your cd player,go to MENU and select both to ,AUTO.
Posted on Feb 18, 2007
What is the wires colors coming out of the jvc
Memory (+12v Constant) Yellow
Ignition (+12v Switched) Red
Ground (-) Black
Power Antenna Blue
Amplifier Power-on signal Blue/White
S p e a k e r s
Right Front (+) Gray
Right Front (-) Gray/Black
Left Front (+) White
Left Front (-) White/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Left Rear (+) Green
Left Rear (-) Green/Black
hope that helps.
Feb 21, 2017 | JVC Car Audio & Video
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
Jan 10, 2015 | JVC Video Cameras
DVD player of my jvc component system mx-jd8 has turned black and white. is there a code?
Sir there is no code try to change the video setting of PAL and NTSC. Good day and best regards.
Sep 04, 2011 | JVC Televison & Video
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
Where can i find a wiring diagram for my jvc
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Oct 02, 2009 | JVC Car Audio & Video
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Acer aspire 3680 svideo in black and white?
Have you checked The Settings in The Bios.
Your laptop May be set As NTSC Or PAL, displaying on A Different format tv set ?
Try An external Monitor, Or the TV Out if applicable.
If these work in Colour rather than monochrome ( Black And White ) then the fault lies with your svga output on the laptop.
Mike @ compurepair.
May 07, 2008 | Acer Aspire 3680 Laptop
Don't worry you dont have to buy a new camera :) When you press the menu button there should be an options menu. look around for the "effects" options or something along those lines. There is a black and white mode on the camera, my guess is that it turned on somehow. All you gotta do is turn it off.
I hope that this helps, feel free to ask more questions. I have a jvc video camera just like this one, so if need be i can just look at mine!
Jan 15, 2008 | JVC GR-AX940 Camcorder
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
JVC MX-J900 CD Shelf System Logo
81 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
