Question about Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax
Cannot fax out or receive on CX5800F
Have had trouble printing and copying, but that has been corrected, but still cannot fax out or receive. Telephone line is good.
Shirley Barnes 480-383-3118 Cell
If you give me a phone number to call for help, I will call.
Thank you,
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
  • 84 Answers
SOURCE: help
no.you need dial tone to send faxes. dsl is for computer use.
wg
Posted on Feb 11, 2008
SOURCE: Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Posted on Feb 23, 2008
leroyal
  • 2120 Answers
SOURCE: all in one printer for Time warner phone line
ALL fax machines are ANALOG and will not work on a DIGITAL phone line. The new trend now is scan-to-email
Posted on Feb 20, 2009
  • 526 Answers
SOURCE: Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Posted on Dec 11, 2009
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Fax can do copies and send but not able to receive incoming faxes. Did several tests. Modem picks up but doesn't transmit data. LCD screen does not indicate any trouble or alarm.
It's possible that somehow the incoming faxes are going directly to memory and not printing. If there was a Tx issue, you'd get an error message on the LCD screen or a printed out message. Not knowing what kind of machine you have, I can't give you instructions to print from memory but if you check your manual, you should see instructions to both print from memory and set the fax to print automatically.
Nov 18, 2009 | Office Equipment & Supplies
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Can not receive fax on Canon Laser Calass 710 Faxmile.
Line noise could cause trouble. I don't know if this unit supports VOIP phone lines. Many fax units require a genuine analog line or something that reproduces an analog phoneline.
Can you test the unit with a genuine analog line?
Nov 17, 2008 | Canon LaserCLASS Fax 710 Printer
Fax Machine Samsung Model SCX-4521F
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Epson Stylus Multifunction Printer/ Copier/ Scanner/ Fax Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
