SOURCE: works only when steering wheel is strait
check the wiring under dash around the steering column the steering column can be rubbing on a wire cousing it to short out
SOURCE: I have a 2004 Dodge Intrepid 2.7L SE. As I was
Sounds like the impact bent something such as an A frame or Tie rod or it could be as simple as an Alignment issue. You'll need to get under it and inspect the Front suspension for any bent components and replace those if these exist. If there are no bent components then have the alignment checked and align as needed..
SOURCE: Isuzu 3.0 TD 2005 - Steering wheel makes squeking
try spraying some silicone spray around the steerin wheel where it mates to the column or rub some dry lube or grafite powder have had sucsess with carpenters pencil poke it in the gap and run it all the way around
