Question about Columbia Telecommunications Group SVND-14S (14 Channels) 2-Way Radio
Transmit no recieve
I read through the other entry's regarding the same problem I am, but I know its not the crystals or battery. As for the step on the private line or what ever, i have no instruction booklet and dont know what any of this means. Please help!! Mike
I also tried to reach Columbia Telecommunications using their website Contact information and the call would not go through. (631) 501-5000 I wonder if they need a "bandwidth" or something and it is no longer available and that's why our units are no longer working. I plan to go to Best Buy to find out why I cannot contact them,...
Posted on Feb 15, 2007
  • 123 Answers
Mike 2 things are needed to get 2 radios comunicated 1 channel, 2 the Squelch code, if both are the same in each radio (same chaennel and same code Ex. Ch 5 Code 22) the radios must to be comunicated. Press the menu key to change each of this features The Squelch code can be PL or DPL, no matter wich one are you using, just need to be the same.
Posted on Feb 05, 2007
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
I have a motrola cp110 that will recieve transmissions, but will not itself transmit. When i press and hold the transmit button, it lights to show that it should be transmitting, but does not transmit any...
Check your programming, and also check your battery. It will take more energy to transmit than to receive. Sometimes this is simply an indication of a bad battery. If this does not solve the problem, you might want to have your radio serviced. (Current flat rate repair is around $85 at dealers where this model is repaired.)
best regards.
May 22, 2011 | Radio Communications
The remote entry is transmitting a signal but it will not work.
There are ways to test it but how do you know that it is transmitting a signal? Batteries are new in the remote also right?
Jul 21, 2010 | 2000 Volkswagen Jetta TDI
Galaxy 99v off Frequency
it is either a bad soilder on your crystal or your crystal is going bad
Dec 15, 2009 | Galaxy Radios DX-99V 40-Channels Base CB...
2002 trailblazer keyless entry unable to reprogram fobs
you should be able to have them tested at parts department at chevy dealership and I dont think they will charge ya. I may be wrong but they can test them.otherwise it could be a unit called a liftgate module is what recieves signal
Jun 25, 2009 | 2002 Chevrolet TrailBlazer
Receiving fine but transmitting bad??
First off, that radio will not transmit very well anyways.  but for just off roading it should suffice.  You really should adjust your antenna's both of you.  First off this is almost definitely the problem if you can recieve but not send.  Also if you use the radio without a properly adjusted antenna it will destroy the radio over time, sometimes instantly.  pick up a cheap SWR meter and follow these steps: Plug the SWR meter into the radio, and the antenna. Start on channel 1, the meter should have a switch with 2 settings, one for adjustments and one for reading.  Key up (hold down talk button on mic) with the switch in adjust mode and adjust the knob until it reaches the adjustment marker. flip the switch to reading and key up again. Your goal is to get this reading as close to 1.1 as possible, anything above a 2.0 will damage your radio. if the reading is within range repeat for channels 20 and 40. good luck!
Dec 31, 2008 | Cobra 19 DX IV CB Radio
I am having a problem with my cordless phone
More that lightly either the base might not be transmitting or the base transmitter could me off frequency. In the past one of the IF oscillator crystals fail. How are the batteries in the handset?
May 09, 2008 | Lands Phones
Neither Radio Transmits or Recieves
Have you checked that both radios are in the same Channel and the same Squelch Code? are the batteries ok? any rust in the battery contacts? Some FRS radios gets a Malfuntion, and the syntom is like that, check this first
Nov 26, 2006 | BellSouth 2231TE (22 Channels) 2-Way Radio
Columbia Telecommunications Group SVND-14S (14 Channels) 2-Way Radio Logo
116 people viewed this question
Top Columbia Telecommunications Group Radio Communications Experts
Michael
ka4iup
ka4iup
tvopft
Level 1 Expert
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
