Question about Orion 2500D Car Audio Amplifier
My Orion 2500D amplifier turns off then back on at high volume
I had this amplifier running on my 02'trans am Ws6 with the regular car battery (primary) plus a yellow top optima in the trunk in addition to a 1.0 Cap (I have read many reviews that states this amp needs 13.8V continuous power to run). i had this amp pushing 2 12" orion 2500 watt subs for about 6 months until it started to turn off then back on at high volumes. i removed the entire system for about a month or 2 for other reasons then reinstalled it all over again...it lasted about 2 weeks without a problem, then it started again... -Do i need a stronger alternator? -is my amp going out? -Do i need thicker cable? or is it just something else. please give me some advise ASAP.....
Well i have two clarion 12 inch duel voice 2 ohm 1000 watt compition subs with a 800 watt clarion amp im running 4 gage threwthe whole car but my amp shuts off and on this is a prefict set up every body is saying no body can figure it out?
got any ideas
Posted on Sep 18, 2008
Bad ground, bad electrical.
Toss the Capacitor
Get a second battery near the amp
Run 0 Guage
UPGRADE 2 THE BIG # to 2 or 0 guage (alternator to batter) (alternator to ground) (battery to ground)
Posted on Jul 14, 2008
    Problem Solver:
  • 14 Answers
You need a # 4 gauge wire. check the subs conection no less than 1 ohm. check ground. and if the cap is good. 13.8 volts are for max ouput ......this is 1 ohm of charge at 13.8 volts they give 2500 watts butt only at 13.8 volts whit this relation. i¨n think you need other alternator. good look.
Posted on Feb 12, 2007
    Problem Solver:
  • 5 Answers
Sounds like your battery is getting weaker. At high volumes it will slowly drain and then shut off and then drain again and then shut off again. Replace it and put another near the amp. Alternator still isn't a bad idea at that wattage. It would probably keep your batteries from failing so quickly.
Posted on Aug 24, 2007
SOURCE:
WHERE IS THE POWER FUSE ON A ORION 2500D
If the fuse is not on the outside of the amp, usually near the live input. it will be inside the amps casing. you may have to look around carefully as maybe under parts or hidden. if not on ouside of amp, 100% its inside the amp
Feb 27, 2011 | Orion 2500D Car Audio Amplifier
I have an Orion 2150sx and an Orion xtr2150 will either of these run on a one ohm load ? If not what is the best way to run either of these amps to get the most power out of them. I have two Orion xtr...
EITHER OF THEM WILL WORK AT ONE OHM WITH NO PROBLEM, MAKE SURE YOU MAINTAIN VOLTAGE INTEGRITY, USING EITHER 2 OR 0 GUAGE POWER AND GROUND AND A POWER RATED ALTERNATOR AND BATTERY.
Nov 03, 2010 | Orion 2500D Car Audio Amplifier
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My orion d5000 cuts out at high voloume for a few seconds then comes back on ????? why
Hello m3_sam,
You did not say what you have the amp wired to and what impedance. Since the amp produces more power at a lower impedance, it does make a difference.
At 4 ohms, the HCCA-D5000 delivers 1000 watts RMS. The higher the volume, the more the amp needs to draw from the battery.
Assuming everything is installed according to specifications, especially the dual 4AWG power and ground connections, it's likely that your vehicle battery/alternator is simpy not able to keep up with the current demand of the amp at high volume. You should probably consider upgrading your vehicle alternator and/or battery. In addition, consider a "Big Three" upgrade. This involves replacing or supplementing the battery positive, vehicle negative, and alternator cables to ones of larger gauge that will allow more current flow. Installation of a capacitor could possible solve the problem, but with the current demands of your amp, I wouldn't count on it.
Hope this helps.
Apr 22, 2009 | Orion HCCA-D5000 Car Audio Amplifier
*amp to sub wiring help...
The 2500D has 2 "+" and 2 "-" power connections to help split the current between two smaller wires vs. one giant, hard to route wire. According the manual, for optimal performance, both "+" and "-" power connections should be utilized. They also recommend using 4AWG wire for these connections.
The 2 "+" and "-" speakers connections are only there to simplify the wiring of multiple speakers into the amp. Both "+" get tied together inside the amp, as do both "-" connections. In this case, with the dual 2 ohm voice coils on your 12" sub, you would wire one voice coil to one +/- set on the amp and the other voice coil to the other +/- set.
Mar 03, 2008 | Orion 2500D Car Audio Amplifier
Im not get any loud base, even with the gain at full turn
an orion 2500d requiers 2 4 gauge power and ground wires to work properly.
Aug 22, 2007 | Orion 2500D Car Audio Amplifier
Wiring for 2500d orion amp
ground wires(heavy black)is connected when the red light lit.so no need check the red hot wire which is connected to battery terminal maybe loose.or theres no power comming in.thre are 2 hotwire in that amp one is red which is the main and yellow or sometimes orange which is the remote on. now if you sure that the power terminals is properly connected,ur speakers is working and input wires are good and still no sound. your amp is probably gone...do not try experimenting the wires or hook up two amp by any means..u might destroy all ur amp. hope this help u....
May 11, 2007 | Orion 2500D Car Audio Amplifier
Volume fluctuates???
-Your head unit has a sound monitor that increases volume to compensate for road noise. -Your amp isn't receiving enough power.
Oct 23, 2006 | Orion 2500D Car Audio Amplifier
Orion 2500D Car Audio Amplifier Logo
699 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
