Question about Statpower PORTAWATTZ 300 Watt Power Inverter Car Speaker
Fault lite on. no pwr to outlets
Fault lite is on, no pwr to outlets
    Problem Solver:
  • 22 Answers
Check fuses on unit
Posted on Dec 03, 2008
Does S5700-24TP-PWR-SI-AC support 802.3at PoE+?
Yes, the S5700-SI PWR complies with IEEE 802.3af and 802.3at (PoE+)
And Huawei S5700 Series Enterprise Switches provides LI (Lite), SI (Standard), EI (Enhanced) and HI (Hyper) models for users. There are some differences among these four versions.
Click this PDF to know more
Comparison of Huawei S5700-LI, SI, EI and HI Series Switches.pdf
Source:S5700-24TP-PWR-SI-AC
Sep 27, 2017 | Computers & Internet
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
Where is fuse for 2005 KIA sportage ac/dc
on the drivers side knee bolster there is a fuse box cover. on the inside of the cover should be a fuse chart. They are usually just called pwr outlet. sometimes there are 2 fuses. they will be labeled pwr outlet 1 and pwr outlet 2.
Oct 21, 2014 | 2005 Kia Sportage
What is the building wireing fault
Your unit is telling you that the outlet is not wired properly. Check for proper hot, common and ground at the wall outlet.
murf427
Aug 24, 2012 | Tripp Lite Lite Internet Office 280 UPS...
Where is the fruse for the left aux power connector below the radio -
The fuses for the auxilliary power outlets are located in the rear fuse panel located under the left second row seat.
The fuse for the console and two front outlets is fuse #46 (20 Amp) and is marked "AUX PWR 1"
The fuse for the rear power outlet is fuse #15 (20 Amp) and is marked "AUX PWR 2"
Dec 01, 2010 | 2003 Chevrolet TrailBlazer
My HP media center desk top will not turn on. I have checked power and switched main plug. My son recently cleaned out the dust and showed me where to plug more power to speed the machine up. Which I...
make sure that this machine does not have switch on the pwr supply on back of pc.some times it is hard to see it. make sure there is pwr to the outlet and try different outlet. do you see any lights on back or front of pc. if not means no pwr is coming to pwr supply.
Dec 12, 2009 | Computers & Internet
No power, no cooling, no light
check your outlet with a lamp to see if you have outlet pwr,then chk pwr cord, normally not cord(chk the easy things first!!!!)
Jul 19, 2009 | Emerson (025806803716) Wine Cooler
Satelite Toshiba M45-S165. WOrked fine, now won't boot
To sure the battery problem or bad. try to change another battery for testing only befor you replace at all.. I thing this over charging of the battery. then the battery became damage or bad.. to sure change other battery..
Thanks
May 11, 2009 | Toshiba Satellite M45-S165 Notebook
No power ay outlet
Maybe unpluged power/ground on plug. take off trim to access back of pwr outlet. It should have grnd wire and hot wire. Test hot wire with a different ground. If it tests ok, relocate ground/run a new one. If it has no power, recheck fuse or run a new hot wire from fuse panel.
Sep 09, 2008 | 1992 Jeep Cherokee Sport
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Statpower PORTAWATTZ 300 Watt Power Inverter Car Speaker Logo
165 people viewed this question
Top Statpower Car Audio & Video Experts
xxxxxx xxx
Are you a Statpower Car Audio and Video Expert? Answer questions, earn points and help others
