Question about HP OfficeJet K80 All-In-One InkJet Printer
Error: Incorrect color cartridge installed
It;s an HP Officejet K80xi and i have the same cartridge in it, it is refilled so i used to have the install color cartridge message on but now it's not working at all
thanks
SOURCE: HP OfficeJet G85
If its not recognizing the cartridge you probably need to go inside and clean the contacts. Best thing to use is ordinary rubbing alcohol but you should also get a can of dry air from best buy or similar place to blow out any areas you can reach. If you need instructions on how to take the machine apart email me at sanglemyer36@yahoo.com
Posted on Mar 05, 2008
mspcrepair
  • 169 Answers
SOURCE: HP PSC 750xi - Incorrect color printer cartridge installed error
It's a long shot, but I would attempt to reset the device back to defaults. If this HP has a "menu" feature, then factory defaults should be an option. Before doing that (and I know this is a dumb question), have you turned the printer off, then turned it back on after a brief rest?
Let me know if this helps and please remember to rate those who assist you :)
Posted on Sep 29, 2008
MUKHTAR
  • 2022 Answers
SOURCE: error - cartridge incorrect
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 16, 2010
SOURCE: How can I fix my HP Deskjet F4280 cartridge error message?
hi..i have similar problem with anjulyn80..i bought a new cartridge but still got a cartridge error in it..
Posted on Jul 22, 2010
  • 78 Answers
SOURCE: I installed a refilled HP 94 cartridge in my HP
This is a firmware issue with this printer model, and is fairly common. Try the following: remove both of the print cartridges, close the lid, wait for any noises to stop, and pull the power plug out of the back of the printer while it is still on. Wait at least 10 minutes with the cord disconnected. Plug the power back into the printer, wait for the noises to stop, and then reinstall the cartridges, black first (very important), and then the color. This will force the printer to reload its ram memory and should take care of the glitch. Let me know if you need further assistance, as I would like to be sure your problem is fixed.
Posted on Sep 30, 2010
Cartridge error saying tri color incorrect
replace color cartridge or refill an old one
like this
Jun 21, 2010 | HP Officejet 5610 All-In-One InkJet...
HP officejet 7210 error message color ink refill
this error is recomded for the printer becouse printer will count the print out
Apr 12, 2010 | HP Officejet 7210 All-In-One InkJet...
Incorrect color cart error message after refill v40xi #78
There is something wrong with the electronics on your cartridge. Sounds like wherever you got it refilled didn't electronically test the cartridge to make sure it would function in your printer. You need to return the refilled cartridge either for your money back or a new refill.
Feb 17, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I had my black ink cartridge refilled professionally, and printed several pages before receiving an "Error: Incorrect Cartridge" message. The printer is also making a loud grunting sound when I turn it on...
you have 2 different problems
1)  "Error: Incorrect Cartridge"  you get cause your cartridge had air bubbles inside and that damage the printhead
air bubbles must be removed before use ether with a vacuum refill or a refill clip as this video
http://www.youtube.com/watch?v=dhDaKSzou50
2) the loud grunting sound you get it either couse the cartridges are stuck or cause paper is stuck in the paper path and do nt let the cartridge carrier to move free
Jan 15, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Have hp v 40 problem code reads; Error incorrect
Try some of these steps:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00299&lc=en&dlc=en&cc=us&lang=en&rule=13018&product=60630
If it doesnt work then try with an original cartridge ,some printers don't like refilled or the refilled is not a good one.
Jun 23, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP K80 OJ with various printing problems
My solution turned out to be a trip to Goodwill to make a donation and a trip to Costco to buy a new all-in-one machine. The economics of fixing this printer did not make sense otherwise.
Thanks
May 11, 2009 | HP Office Equipment & Supplies
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet G85
Feb 19, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
