Question about Linksys Wireless-G Broadband Router
I had to buy a new lynksys wireless router and I have to put it on the computer so I can use it correctly.
  • Linksys Master
  • 6,487 Answers
Since this is a new router you can just run the setup CD that came with the router and follow the step by step procedure there , but if the setup CD failed you can just contact Linksys tech support so a tech can wlak you through with the process on how to manually configure the router, this is the number 800-3267114 they are open 24/7...
Posted on Dec 03, 2008
Have lynksys wireless router but is unsecure -
You can enable WEP on your router to make your wireless network secure.
To access the screen of the router, type the ip address of the router in the address bar of Internet explorer or Firefox. By default the ip address of the router is 192.168.1.1. If this doesn't work, go to the command prompt (Start -> run -> type cmd). Type ipconfig. Copy the default gateway.
It will prompt you for a user name and password. By default leave the user name blank and then type admin in the password field.
Once you are in the Linksys screen, go to the Wireless tab -> Wireless security.
For the security mode, select WEP.
WEP encryption: 64bits 10 hex digits.
On the Passphrase field, type a wireless password of your choice, then click Generate.
It will give you a key. You will need to copy the wireless network key because you will need to enter this key on your PS3 and laptop. Take note that this is also case sensitive.
Once you click save settings, it will disconnect all your wireless computers.
You will need to manually enter the wireless network key on all your wireless devices. Without the network key, other computers will not be able to connect to your network.
I hope this helps.
Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated.
Feb 16, 2010 | Linksys Wireless-G Broadband Router
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
We have a lynksys router. It is 2 years old.
upgrade the router to the latest version of firmware and reconfigure the same.
Also remove the existing saved connections from ur computer and then readd the new connections after reconfiguration of the router.
Jan 11, 2010 | Linksys WRT54G Wireless-G Broadband Router...
I have a Lynksys Wireless-G brand WRT54G2 router connected to my High Speed Ethernet Modem and to my desktop computer. It puts out a fairly decent signal to my laptop across the house through walls and...
Yes. 1. Disable the DHCP in the belkin router. 2. Take the cable from the LAN port of the Linksys router to the LAN port of the Belkin Router. 3. Dont touch anything else in any of the routers.
This should help
Thanks Ranjit
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
Cannot get internet connection
You probably have to buy a wireless card and and install it in your computer...there wasn't much in the way of home wireless back in 2002.
Go to your device manager and look at the network adapters and see if you have a wireless adapter installed on your system. If not, you will have to put a wireless pci card in and install it and then you will be able to configure your computer to connect to your router with a wireless connection.
Mar 28, 2009 | Microsoft Windows XP Professional With...
Linksysfix
download lynksys from main computer to portable flash and put it onto your lap top.
Dec 06, 2008 | Linksys Wireless-N WRT150N Router
Lynksys Connectivity Problem
occassionally, the wireless router needs to be turned off and on. The are some issues with regards to the stabitlity of these entry level wireless routers. What I do is put a timer at the outlet to reset it every morning. cheers!
Oct 16, 2008 | Linksys Wireless-G WRT54G Router
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Please confirm that this model is indeed a wirlles Modem/ ADSL Router and not just a Wireless Router without the ADSL/ Modem capability??
Apr 20, 2008 | Linksys Wireless-G WRT54G Router
Wireless router
nee dto buy new pci wilress card be your best bet ok
Feb 11, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
35 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
