Question about Maytag MAV6200 Top Load Washer
Washing machine fills, and thats it.. will not do anything else
Jsut recieved this newer matag atlantis washing machine.. hooked it all up and loaded my first load.. filled.. then no aggitaion no spin no drain..i need help
There is a problem with the lid. Push ******* the front of the lid. It should work. Mine has been doing this for 6 years.
Posted on Dec 26, 2008
My matag atlantis just stopped working. It will
no reset, check the receptical you could have tripped you house circuit or fuse
Feb 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Matag alantis no cold water
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
Jun 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Where is the fuse located on matag washer LATxxx machine filled
yes there is a fuse disconect the power remove he 2 inner philips screws from the top of the control panell you will see a small rectangle pice with a fuse and a2 switches this is a lid switch asmbley you need to replace this hole pice if you just replace the fuse it will do it again
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
131 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
