Question about GE JBP71 Electric Kitchen Range
My oven won't work
When I push BAKE the control panel flashes " un loc dor" I called for help troubleshooting but cannot clear it so that I can cook. HELP!!!!
  • 2 more comments
  • betty bradford Dec 04, 2008
    No error code. Only " un loc dor "
  • mrgreer Jan 30, 2009
    I have the same problem with my GE model J-BP35DOK1WW
  • Shaun Plencner
    Shaun Plencner May 11, 2010
    what brand of oven and more info needed
  • Shaun Plencner
    is there a error code flashing
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: dead control panel
No F7 or E7 in my tech sheet could it be a F1 F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad let me know thanks
Posted on Aug 26, 2007
  • 20 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Posted on Jan 27, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
  • 107 Answers
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
localwonder
  • 6784 Answers
SOURCE: Flashing locking door light
This is a failed logic chip on the control board. replacing the control board will fix this issue.
Posted on May 27, 2009
Replaced the LCD pad computer. getting a LOC rEF code. What does it mean or how do I clear it?
If this is a GE oven:
1. Make sure power to the wall oven is turned off_
2. Completely close the wall oven control panel and return the wall oven to its normal installation_
3. Apply power to the wall oven. Accessing the control panel area but not replacing the control:
4. Enter Special Functions mode by pressing the BAKE and BROIL keys at the same time.
5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
6. Approximately 20 seconds after the time of day is displayed. press the 1 and 5 or the TEMP LIP and MINUTE UP keys. The control should briefly go blank, briefly display all segments. briefly 'display "LOC FIEF," display all segments for 30 seconds, and then display "LOC REF:"
7. Acknowledge the "LOC REF" command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. The control should then display the time of day,
8. The oven should be ready for normal operation.
9. Test the functionality of the glass touch contra especially the CLEAR/OFF and/or CANCEL key(s)..
Nov 26, 2015 | Kitchen Ranges
Oven wont ig night but broiler works
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Oct 22, 2012 | Frigidaire FGF316 Gas Kitchen Range
CONTROL PANEL FOR OVEN NOT WORKING AT ALL
Hi - I understand that the burners work, however I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed, confirm that there isn't a wiring failure or a faulty element.
Oct 17, 2012 | Frigidaire FEF366 Electric Kitchen Range
Electrolux oven won't heat up at all
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 27, 2012 | Electrolux 30 Inch White 30" Electric...
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Flashing bake and probe indication on GE JD968S
I found the Mini-manual inside the control panel area of the range. I followed the instructions for resetting the control. Instructions are shown below:
Glass touch models only- Lock Reference Command
When the control panel is accessed, the signals used by glass touch panel may be adversely affected. To compensate for this change in signals, the following procedure must be followed every time the control panel is accessed.
1. Make sure power to the range is turned off.
2. Completely close the range control panel and return range to it's normal installation.
3. Apply power to the range.
Accessing the the control panel area but not replacing the control.
4. Enter Special Functions area by pressing BAKE and BROIL keys at the same time for 3 seconds.
6. Approximately 20 seconds after the time is displayed, press the 1 and 5 or the TEMP UP and MINUTE UP keys. The control should briefly go blank, briefly display all segments, briefly display LOC REF, display all segments for 30 seconds, and then display LOC REF.
7. Acknowledge LOC REF command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. the control should then display the time of day.
8. The oven should then be ready for normal operation.
9. Test the functionality of the glass control panel, especially the CLEAR/OFF and/or CANCEL key(s).
Steps 4 through 7 are appropriate if you have not opened the control panel area. I had to open mine to clean up moisture caused by a boil over.
Judging from the number of inquiries on this same issue, this is a common problem. GE is more than happy to schedule a service call for this issue, but not so happy to give the information over the phone. This is a fairly simple procedure for most people to accomplish.
The ERC on my range appears to be a fairly common unit. I hope this information helps.
Sep 22, 2008 | Kitchen Ranges
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
My oven says LOC and it is not locked
Today the "Loc" light came on and I can not use
the oven... the oven door does open and the
cook top works ok?
I see two others have the same problem.
I tried to un-plug the electric plug but this did
not re-set it?
This unit is about 7 years old. I can not find
the manual. There is no re-set button anywhere
and I also can not find a model number on back?
Oct 18, 2007 | Kenmore 95680 / 95681 / 95682 / 95684...
GE JBP71 Electric Kitchen Range Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
