Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
FRONT DISPLAY SHOWS (PE0-000)
I just put a new hv board in my new maytag ice 2o and now the display reads pe0-000. the compressor works but nothing is getting cold. any suggestions would be appreciated. thanks, biggin.
  • tim carn Feb 06, 2007
    this unit was bought as a scratch and dent it was said to need a new control board. it now has a new hv board and a lv board. the manual that came with it does not show any info on the digital components. i don't think it will cool without the display working. since this is where the freezer and refrigerator degrees are set.
  • hydromax Dec 31, 2007
    I have the same problem with the display showing PE0 000. pressing buttons don't do anything. What should I do now ?
    New Friend:
Well the key here is FIND THE PAPER UNDER THE FRIDGE TO REPROGRAM CONTROL BOARD!!!
Posted on Jan 01, 2015
TO KEEP YOUR FRIG WORKING UNSCREW THE TOP LEFT HINGE COVER AND PULL APART THE PLUG, FRIG WILL CONTINUE TO COOL TILL A REPLACEMENT BOARD IS INSTALLED.
Posted on Oct 01, 2007
  • fostercline Dec 20, 2014
    On ours, the Code is inside the refrigerator on the upper right. Instructions were found In a hard to find plastic sleeve pasted on the bottom of the refrigerator are directions: As follows. Reprogram the key pad as directed with the code. 1) Press and hold DOOR ALARM Keypad. 2) Pres and hold FREEZER down key. 3)Relase the Door Alarm Key and wait 3 seconds 4) The control will display PE to indicate programming mode. 5) Entry is confirmed by pressing the FREEZER temp down once more. 6) The control will display the current program code. (000 for ours) so this needs to be changed if incorrect. 7)Press the REFIGERATOR temp up key or down key to change the digit value. 8)The decimal point indicates the selected digit. 9) Once the desired code is entered, press and hold FREEZER temp down until flashing indicating all is saved. If you attempt to enter an invalid code, the control will not save, but beep. Programming mode is exited by pressing any key.
YUKONJACK IS RIGHT I had the exact same problem so HERE IS THE REAL SOLUTION: The first post by schwab is only HALF CORRECT. After the board is replaced it has to be programmed from the front digital display board key "+ and - keys" There is a code on the inside of the fridge that needs to be entered using the keypad on the front for temp adjustment etc and a specific sequence to set the program. If not done properly your fridge will not work but will look like it is. Call Maytag for FREE REPLACEMENT. They did mine. FG-Systems Engineer-I watched very closely what they did. Parts may be back ordered because EVERYONE HAS THE SAME PROBLEM
Posted on Sep 08, 2007
  • 237 Answers
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Posted on Feb 06, 2007
When the hv board is replaced, the display must be re-programmed using the code inside the upper compartment on the right side.
Posted on Jun 04, 2007
HV board problem. replaced board, but can not reprogram to enter new code. what do I do?
I recently had the identical problem after replacing the high voltage control board myself. Although display looked normal, no response to programming attempts. All I could think of was that the low voltage board under the display ppanel was also bad and was about to go out and buy it ($240 locally) when I ddecided to check its connections first. Took off the display panel, unplugged the 4 connectors, plugged them all back in. When I powered up the fridge, it responded to the programming directions and has been working normally except the ice-maker made one batch of ice and then just stopped. Now I have to try figuring that one out.
Aug 11, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Changed HV board on a Maytag MFI2266AES because ice dispensor and water did not work. Now PEoo ooo is shown on the display where temp read out used to be shown.
Did you check the low voltage supply going to the board? I'm pretty good with that model Only problem is I can't pull that model number up. Looks like you have an extra number or letter. You should get 16 volts from the low voltage side of transformer. Sea Breeze
Oct 15, 2009 | Maytag MFI2266AES Stainless Steel Bottom...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
MAYTAG refrigerator (MF12568AES) entering code
Call Maytag. They are aware of the problem. When I called them last year, they sent me a new control board for free, but they didn't provide labor. We got someone out here to install the new board thru our home warranty. We paid $65 for the labor. Not sure how much Maytag will charge.
Aug 22, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerator not working properly
dispenser board needs to be replaced. There was a recall on certain Ice 2O units. Call Maytag and see if your unit qualifies.You will need model and serial number.
Jul 23, 2008 | Maytag MFI2568AE Side by Side French Door...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Dispensor display going haywire/ ice shoot valve opening by itself
It is not the circuit board in the door, it is the one in the rear of frig. I had the same problem, and replaced the front board with no results, replace the HV board and fixed the problem..
Sep 21, 2007 | Maytag MFI2568AE Side by Side French Door...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
3,163 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
