Question about Acer Computers & Internet
Hi boughr Acer monitor 191w.IT HAS 15 PRONG AND 24 PRONG LEADS CONNECTED TO MONITOR BUT i DONT HAVE A 24 PRONG OUTLET ON MY COMPUTER.i HAVE NO SOUND SO I AM ASSUMING THIS LEAD IS FOR THAT.i have another spare 15 prong outlet on the back of my computer.Would it work if there was an adapter to connect this 15 and 24 prong leads together
    Problem Solver:
  • 17 Answers
No just connect the 15 prong vga plug and dont worry about the 24 prong one15 prong is vga and 24 is dvi both are for video and will not affect the sound. The audio should have a jack plug on it.
Posted on Dec 03, 2008
I can't find the location to plug the speakers in on my acer monitor.
is it an acer monitor or
Acer (90.00012.30B) Computer Speakers Reviews
are you sure they need to be connected to a monitor if they have a usb connection they will plug into a usb port or if they have plugs the speakers into the speaker outlet usually at the back of a computer then
control panel sounds and audio,volume,advanced,speakers select the appropriate speakers
hope this helps
Jun 25, 2011 | Acer 90.00012.30B Computer Speakers
Yes, you can use the monitor leads from other monitors, just make sure that the pins are the same.
Some monitors have a 9 pin connector, and others have a 15 pin connection.
The jacks will look the same, but the 9 pin version will have the other pin holes filled in.
As a rule though, most modern monitor cables should work for you.
I hope this helps, and good luck.
Mar 14, 2011 | Hansol H550 15" LCD Monitor
Blanck screen
Make sure that you have selected the right input on your monitor. Usually laptops have an analog output (a plug with 15 prongs in 3 rows), and thus you need to select analog input on your monitor.
Also when you press the appropriate key combination on your laptop (usually Fn + F8), wait, say, 15 seconds for reaction before you press it again - it takes some time for the monitor to come back from power saving mode.
Oct 24, 2009 | Acer 22" X223w LCD Monitor
I have no sound on my Acer monitor
ACER X223W have no speakers build in. You must use exstra speakers or a headset.
Jul 26, 2009 | Acer 22" X223w LCD Monitor
I am trying to connect my Acer Aspire Desk top and my Advent 4211c Notebook to this screen using a 15 PIN Analogue Monitor Lead .VGA Monitor Cable ? No luck ?
There is a switching methode..pressing the Fn switch then F4 (One Monitor Symbol is there),you will get the result..
Jul 10, 2009 | Computers & Internet
Color on Acer 191w
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
Jun 24, 2009 | Acer X193W LCD Monitor
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
22" Acer flat screen monitor
this sounds like an electrical fault or failing component, within the Monitor.
Check the cabling, to ensure it,s not damaged-broken-kinked et,c. by carefully moving the cable gently side to side and up and down.
If it puts itself right for a second or two. you can assume its a broken internal wire, within the lead.
Or a dry soldered joint-Connection.
Mike @ compurepair.
Sep 16, 2008 | Acer AL2216WBD LCD Monitor
Studio monitor chaos
Please change your probes or change your volume control knob as quickly as possible because it has been got damaged...
Thank you...
Nov 28, 2007 | M-Audio DX4 Active Studio Monitors (Pair)...
Screen rolls
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
