Question about Samsung LN-S4692D 46 in. LCD HDTV
Samsung flat screen tv 2 weeks old turns off 15 minutes sometimes will not turn on makes clicking noise
  • Anonymous Feb 12, 2009
    TV just clicks and power light flashes 5 times. Sounds like repair shop won't even be here for 2 weeks. I have Model LN46A650A1FXZA 46" LCD. called support, very bad english, guessing India. Had to repeat EVERYTHING to the lady. Call 1-800-726-7864 have model number and serial number and be patient, hard to understand language and they have a hard time understanding you. Was put on hold repeatedly. Not impressed with customer service.
  • 98 Answers
Need to get warranty service & replace the main board
Posted on Feb 09, 2009
I have a Samsung Flat screen TV model LN T4071f8 and when I turn it on it just makes a click click click noise and then sometimes it will turn on.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 15, 2015 | Samsung Televison & Video
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a Samsung led, high definition (1080i) bvd, srs tv, after about 10 or 15 minutes the screen goes blank but you can still hear the sound, if you turn it off and on it will work for around 15 minutes...
Hi, i have the same problem but not always at 15 minutes, sometime longer and sometime shorter. However it is the same symptom. I put a table fan right at the lower back of the TV and blow it upward at about 45 degree to make sure the air blow inside of the TV as much as possible. I used this way for a month and haven't had any black out problem. The only thing that you have to live with is your fan's noice. Good luck to your.
Jul 19, 2010 | Samsung Televison & Video
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
