Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Image too big for screen
I was at a friends house & on his Sony Wega (I think it is the 50" model) it looks like the HD image is cropped a bit to fit the screen (e.g. can't see the scores of football games). The full image does show in the PIP insert. The Wide Screen mode selection does not have "full" available (greyed out). video source is via HDMI from the HD Cable box.
Any idea what to do to fix it?
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Posted on Dec 11, 2008
Image Is to Big
Go to Menu Settings Picture Check the the picture settings Select the format which fits on your screen OK/Save the settings.
Aug 24, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a 50' Sony Grand Wega red bar on top of screen
Well this is an LCD projection TV and it sounds like one of the polarizer filter has gotten out of place so you are seeing at the top of your screen the unfiltered image of the LCD panel.
Will need to go into a shop to get repaired. Call and get an estimate of repair. Actually shouldn't be too bad of a repair cost.
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Wheres is the lamp located on the sony wega 50 inch tv
remove the two small covers left and right behind the front lower panel.remove front lower panel (its a firm fit) pull in this sequence 1 rht top, 2 left top, 3&4 lower mid. lamp behind a panel just to the left of cantre, remove two screws locating it in place .pull lamp housing out
Sep 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue ghost image on left side of screen
The Optical Block Assy would have to be replaced, same part that causes Blue Dots, not considered to be user replaceable.
Mar 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-50WE655 50 in picture is dark
I had the same and replaced the lamp - made a big difference. Got the bulb on Ebay for $82.00 with free shipping. Just the bulb without housing, seller has instruction online for changing bulb - very easy. River Valley Electronics
Here's a link
http://cgi.ebay.com/XL2100U-XL-2100U-A-1606-034-B-A1606034B-LAMP-FOR-SONY_W0QQitemZ370154719357QQihZ024QQcategoryZ149975QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Mar 13, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Static line
it might sound strange but i think the screen has dropped. I have seen this happen before, is it just one line or 2 as the screen is fitted in the shield, its held by a thin rubber sometimes it can drop when the tv is being moved about or in a lot of vibration like moving it about in a car. now this may sound strange but the last time i fixed one i used 6 match sticks and clean them up and put them in the screen housing and it keep the screen in place after that. but beautiful when removing the screen case as you can inadvertently damage the screen, the screen is only a thick as a bit of cardboard. i suppose you could even put the tv upside down on the bed or something soft and wiggle the screen back into place. this would not damage thew tv and you will not have to take it apart.
Jul 03, 2017 | Samsung HP-R5072 50 in. Plasma HDTV
Sony WEGA KV-27FS100 picture size
hi there, you may have a power supply section trouble, check the biggest electrolytic capacitor in the power supply, the rectifier diode, the regulator, and check for some cold solder, do some test, there is a part to be repalced. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
306 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
