Question about Mitsubishi MSZ09UN Air Conditioner
Intermittent Fault MSZ-A26YV split system air conditioner
Unit intermittently blows cool air (not cold), stops operating and the left hand indicator light on the wall panel flashes 5 times then pauses then flashes for 5 times etc. Have tried turning off power, resetting etc but nothing works. Will operate perfectly the next day (usually the day the service man is coming out to look at it).
  • lesleycasey Jan 17, 2009
    I have same problem but my now only blows air (not cold) for around 20 minutes then stops and light flashes 5 times then a break then 5 times again and continues to do so.will not start again unless I turn of at fuse box then the pattern starts all over again.My service man told me the lights are a code to what is wrong with it.he has to check and will get back to me. LOL LOL LOL
4 Suggested Answers
  • 832 Answers
SOURCE: need remote for a v-lec split type air conditioner
Why not try the dealer selling V - lec aircon? They are
in the best position to know where to get the replacements or clone remote controller for your unit.
Better still try surfing the internet, V-lec Aircon may have
a web site to service their clients. May this info, help you.
Posted on Jan 06, 2010
  • 81 Answers
SOURCE: MSZ-A24NA Split System Air Conditioner: it stopped heating, air comes out but no heat, brr...
Is it defrosting??? Your problem is quite brief and that is the only advice that I can offer based on your question.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
  • 81 Answers
SOURCE: I have an air conditioner Mitsubishi MSZ-A26YV, it
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Posted on Mar 30, 2011
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
DONT KNOW WHAT SIMBLES ON REMOTE CONTROL ARE EG HOT COLD ETC
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Mar 20, 2011 | Mitsubishi MSZ09UN Air Conditioner
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
We have a msz-ga80va split cycle, indoor unit runs for about 5 minutes without cooling then cuts out, outside unit doesn't kick in at all
Just had the same thing happen to us with the same model (right on Xmas day).
Checked the circuit breaker is on in the fuse box. Power is on to the external unit. Filters are clean.
Internal unit activates... both indicator lights on. After 5 minutes blowing air it stops and the right indicator light goes out and the left indicator light blinks constantly.
The troubleshooting guide inside the internal unit (under the outer cover you open to clean the filters) suggests that 14 blinks is an abnormality with the external unit and refer to service manual.
Think we'll be calling a technician.
Dec 26, 2010 | Mitsubishi Heating & Cooling
Does not blow cold or hot air
Haved you cleaned the filter?? Clean them! It might be out of refrigerant. Have the unit professionally checked.
I take the time to help, so please rate me!
May 30, 2010 | Mitsubishi MSZ-A24NA Split System Air...
May 18, 2010 | Mitsubishi MSZ-A24NA Split System Air...
The heat is not getting hot and keeps turning off
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Jan 31, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Mitsubishi MSZ09UN Air Conditioner Logo
142 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
