Question about Aspire Acer 7520-5071 Notebook
Acer Aspire 7520 turns off and on repeatedly
Each time I turn the computer on, the power button lights up and it makes the start up sounds, then promptly turns right back off.  This happens over and over again until i take out the battery or plug. The computer is an Acer Aspire 7520.  It just began doing this today.
  • 4 more comments
  • Nitrocad Dec 08, 2008
    I have the same problem, i have done a bios upgrade, but it wasn't
    useful. Im running an XP on it, and (just) sometimes it plays the same
    problem on start up. Even from sleep! I think is a hardware or bios
    problem...
    Anyone some solution?
    I forget some info, wenn it starts the button lights up and it makes the start up sounds, then promptly turns right back off.
    - the screen is still off, (even by wake up from sleep)
    - and sometimes if i open the DVD-RAM it will continue to starting, or waking up.
  • princessjoy Dec 25, 2008
    I have the exact same problem. How do you re-install the operating system software if it wont turn on. Or how do i repait it using an operating system cd? Where can I download that
  • Anonymous Jan 10, 2009
    If I can't get the system to turn on, how do I remove a possible virus?
  • Hoibie Jan 13, 2009
    No discription, just the same problem.
    If someone knows a solution please mail it to me:
    bjorn.h@live.nl
    I gues its something with the connector of standby it hasn't got a button to get in standby, maby it works with magnets? but don't know where they are in the laptop...
    Also tried a bios update...
    When i opened the backsite and pulled out the RAM and pushes on some chips, he go's on for doing nothing... the screen was closed and he logged in to vista :S
    Please people with solutions mail it!!
  • PCShare.Com
    PCShare.Com May 04, 2009
    Noticed few Quacks here. The problem occurs before it tries to POST. In which case, it's not a Windows problem or the battery issue.
    I haven't figured it out yet, but most likely a short in a motherboard.
OK.To clear this up...
The problem is the nVidia BGA controller which has overheated (due to nVidia CPU overheating) and caused it to loose contact with the mainboard (dry joints).
The only way to fix this is to have the controller reseated (not cheap) or you can try doing it yourself (not recommended) by removing the motherboard and all attached items (e.g. modem/wlan/memory/cpu etc) cover it in tin foil loosly but making sure to seal all edges and heat it in the oven to around 200C for about 20mins making sure the cpu socket is facing upwards.
As I said this is not recommended as it may cause other problems but if you dont want to fork out for a new board its worth trying!!
Posted on Jun 18, 2010
    Problem Solver:
  • 10 Answers
Your cmos battery is loose. The same thing is wrong with mine. If you push down hard on the middle of the keyboard and hold it down it for a few seconds it will boot into windows. I found this on another site. I havn't taken the time to see how to pop the thing open to fix the problem properly.
Posted on Apr 15, 2009
  • kados Apr 15, 2009
    http://www.cyfinity.com/2008/07/acer-asp...
    that's how to remove the keyboard, only 2 screws under the battery though.
    the cmos battery isn't the problem, unless it's shot. It's soldered in and I don't have a multimeter to see if it's charged or dead. I have a couple weeks to get this figured out, so if anyone else has a solution, PLEASE post!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Hi. reading all this i think that i came to conclusion that it may be one of BGA chips with bad connection. Is a south bridge (responsible for operating USB's and CD drive!" on this motherboard anywhere close to the place that you push to get laptop to switch on. Maybe GPU is gone bad that gives similar symptoms. Maybe locating bad chip and reflowing solder underneath it with air gun would solve an issue. If yes what you need to do once you take your motherboard out and locate bad BGA chip get a thermometer that can measure up to 300C and place it by the side of the chip. Slowly warm the chip up with hot air gun till you reach about 200C leave it to cool down and repeat it this time getting it up to about 240C. This should allow for solder to melt under the chip and renew all of the connections. Please post your results if you get to do it.
Posted on Apr 16, 2010
    Problem Solver:
  • 10 Answers
It's not the cmos problem, although pushing on the middle of the keyboard does make it start. But what you're actually pushing is the part on the motherboard where there is all the ICs that are responsible for the power coming from the AC and/or the laptop's battery. Something on the motherboard needs soldering, I haven't solved that problem yet but that's what I know so far..
Hope that helps, and please if anybody solved it email me at: andrexman1@yahoo.com
Posted on Jul 28, 2009
  • 4 Answers
Hello
it is not windows and it is not your cmos batery are you guys that stupid?
it is your processor and/or your ram realy take it out replace it with new ones put rams in your both ram slots and a new (i used turion x64)processor and let it power cycle while your calling acer support because you think it is still not solved
and
it starts wowy this was hard to find out(for the realy stupid people under us maybe)
Posted on Apr 20, 2010
  • 103 Answers
The reason why your pc is repeating this cycle is because a file from windows is corrupt or lost causing windows not to be able to start up. This can be cause by a windows file being infected with a virus or worm and is then removed by an antivirus. You would need to Re-install your operating system software or repair it using an operating system cd.
please rate me. thank you.
Posted on Dec 03, 2008
Solved! shaun Foster was right, pushing on the center of the keyboard solved my problem, it stops restarting and turning off each 10 seconds. my notebook was aspire7220. Now the problem is that the display doesnt work, no reaction, I know is a display problem as I conect a monitor and it displays all.
Posted on Feb 27, 2015
@emwh I was having the same problem as reported and after trying what you posted it helped me. My daughter laptop is now working. Thank you for your post
Posted on Oct 14, 2012
  • angel31675 Sep 13, 2013
    wish one did you try?
    which lol.
Link.to.translate.google
Das Problem: Boot Loop
oder in einfachen Worten, wenn man startet, startet das Notebook alle 2sec neu :-\
Alle haben das selbe Problem, bei den wenigsten war noch Garantie drauf, die mit Garantie haben es eingeschickt und ein paar Wochen später war es wieder kaputt...
┌∩┐ DANKE ACER, FüR DIESEN TOLLEN SUPPORT UND DIESE GEILE PRODUKTREIHE 75xx ┌∩┐
Wir haben das Notebook geöffnet und alles überflüssige entfernt. Mit verschiedenen RAMs ausprobiert, verschiedene CPUs. Graka ist leider On-board.
Der Fehler blieb :'( Bootet nicht, startet ohne was anzuzeigen alle 2sec neu *grmbl*
Vergeblich eine konkrete Antwort zu der Batterie beim Acer Aspire 7520 oder zum CMOS resetten/flashen/kurzschließen gesucht...
Sahen uns schon gezwungen, wie Vorgeschlagen, das Notebook in den Backoffen zu schieben ;]
- Haben keinen fön da ;D -
Schließlich geklappt hat:
Auf diese "Batterie" drücken und +1min den Power Knopf gedrückt halten 8)
(netzteil und akku rausnehmen! Power drücken ist dann wohl so wie "Batterie trennen").
Notebook startet wieder^^
Keine Ahnung, was von beidem der auslöser war. Denk das mit dem Powerknopf, mal sehn wie lange er läuft xD
Eine Frage bleibt:
IST DAS DING DIE BATTERIE (steht dran "BATT1") UND KANN MAN DIE ABMACHEN/ERSETZEN/KURZSCHLIESSEN/üBERBRüCKEN???
Hier ist ein Foto von dem Batterie-Ding bei dem Acer, wie es bei normalen PCs und Notebooks ist und bei anderen Acer'n...
http://www.lupiupload.de/file.php/file/_OftKJE8qG
http://www.ld-host.de/show/7b2acf0aa8b388b0f4d054d123cdb84f.png
http://www.imgbox.de/show/img/3vQ1XcEsB1.png
* 3x selbes bild
Hoffen der Post hilft dem einen oder anderen (^_^)
greetz
priklo und mörda
Posted on Aug 06, 2011
    Problem Solver:
  • 14 Answers
Hello, im a IT Tech and deal with alot of these laptops, andrex man is totally correct. A new motherboard would cost too much so i suggest you look for a good "Re-Heat" service (system board repair) to un-solder the whole board and have it all soldered back together also ... to stop this happening again make sure you clean your 7520 out every now and again as the athlon loves to over heat< or simply uograde to a turion maybe a TH33 or something avaliable due to the spec of the motherboard :)
Posted on Feb 19, 2010
Add another one to the list- will eventually start up but without the dvdrom - loses usb ports at random - have it apart cannot see anything with motherboard. Any hardware or software scans I've done says there is nothing wrong. -- Will
Posted on Jan 07, 2010
2 Suggested Answers
SOURCE: Acer Aspire 7520 turns off and on repeatedly
Mine does this but what I found was that if you hold the power button down for about 10 seconds when you are turning it on, it works.
Posted on Apr 02, 2009
My acer 7220 turns on and off repeatedly
There are some reasons why PCs turns on and off repeatedly.. Maybe the memory card/s does not detect by the system properly. Faulty screen backlights circuit, or there was leaky or blown capacitors in power supply circuit.
Nov 05, 2013 | Aspire Acer 7520-5071 Notebook
My acer aspire 7520-5185 will not turn on
Take out the battery then press and hold power button for about 30 seconds, then put battery back in again and try to turn on. Might as well leave it without the battery for some time after holding the power button. If that doesn't help try removing RAM and turning it on without it.
By the way.. any beeps?
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
I have an Acer Aspire 7520, i was on it today and all of a sudden the screen froze. I couldnt do anything, couldnt click on anything, shut it down, i had to pull the battery and plug. then when i went to...
Do you get the posting beep??
Sounds like faulty ram.
Remove battery / depress on button several X to de-energise system.
Remove ram / reseat / reboot.
Apr 13, 2010 | Acer Aspire 7520-5185 Laptop
I bought my acer in 2008. worked great up until a certain period where it would over heat and shut off. i put in windows 7 and that problem stopped, it wouldn't over heat anymore and shut off. then it...
i would never by an acer my sister bought 3 of them same problem but i had a hp and did that hard drive was failing, yours could be a computer virus too
Mar 24, 2010 | Acer Aspire 7520-5185 Laptop
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
I have a cer apire 7520 which had vista on, But
Need to change your boot sequence so that the computer bios will run the cd at start up When your computer starts you will see it says something like press F12 for setup or press ESC. it veries by computer.
Sep 07, 2009 | Aspire Acer 7520-5324 Laptop
Acer Aspire 7520 doesn't start up!
There should be a F key option at start up during the bios side of boot up. Look closely and quickly at the screen when starting up. You should see on that says retstore maybe.
if not just press all of the F keys skiping the ones listed for start up options and bios option.
Aug 09, 2009 | Acer Aspire 5720-6661 Notebook PC
it looks like your mainboard is cutting the power. mainboard has power issue. need to get service.
May 30, 2009 | Aspire Acer 7520-5071 Notebook
Aser 7520 aspire
If you have no video at all then turn off the laptop. Reseat the memory and then turn the laptop back on with just the AC Adaptor hooked up to see if you get video if not then try reseating the memory into the other slot and try turning it on again to see if you get video. If not then your motherboard may be bad. Just curious though after you turn on the laptop, does the hard drive light keep flickering like its trying to load windows?
Feb 08, 2009 | Aspire Acer 7520-5324 Laptop
Dec 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
Aspire Acer 7520-5071 Notebook Logo
10,134 people viewed this question
Top Aspire Computers & Internet Experts
joecoolvette
joecoolvette
meteshadow
Jax Planet
Jax Planet
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
