Question about Ovens
Elitech 1300W convection oven: How to set it for self cleaning
My instruction manual neglects to even mention the great self cleaning function for my Elitech 1300W convection oven. I can't find any helpfull information on line for my self. I would like to know how to set it to the self cleaning mode. I have seen it advertised and shown on tv bidding but it was a different model to the one I have just bought. Can any body help to confirm the instructions to me for self cleaning function for Elitech 1300w convection oven,  which I now have. Thank you.
Hi
If you watch the advert for the Nuwave or Flavorwave they set the machine to defrost setting.
Put water in and a bit of washing up liquid and put on for about 10 min.
Posted on Dec 09, 2008
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
How do you clean a self cleaning oven? I don't have the instructions. It's a Frigidare gallery convection oven. We bought it used. I just need the Instructions. (it didn't come with any) Thanks Debbie
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 19, 2011 | Ovens
I need instructions to start up the self cleaning for a Refridgeadaire Gallery self cleaning convection oven
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 14, 2010 | Ovens
SELF-CLEAN
Here is a link to your manual.
Owners Manual
FYI - The '55' in your model number should be 'ss' for stainless steel.
May 21, 2010 | KitchenAid 30 in. Architect II Series 4.3...
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Oven won't heat after self cleaning
There is a overload thermostat located on the rear of your oven that needs to be replaced.
Self cleaning operations are not recommended by this technician.
Mar 02, 2009 | Whirlpool Ovens
Dont know how to use
Many ranges now have automatic conversion when you use convection feature instead of standard bake, but as a general rule, if your standard baking time in the recipe is over 30 minutes, you can lower the convection setting by 25 degrees F and reduce the time by 25% to get the same results as standard baking settings. Please don't rate this if you don't feel it is a Fix-Ya for you, as other ratings lower my score. Thanks.
Jan 20, 2009 | Ovens
Ovens Logo
669 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
