Question about IBM ThinkPad T30 2366 Notebook
How do you remove/replace CMOS battery?
The CMOS battery in the T30 is located underneath the main battery.
I did the following:
- I removed the main battery
- Unscrewed the CMOS "container"
However I can't figure out how to disconnect the CMOS wire from the motherboard (I can't reach it).
I removed the keyboard to see if I could reach it from the front side but with no luck.
Any idea?
  • ptrmnr Dec 03, 2008
    but on this movie the CMOS doesn't seem to be connected to the systemboard
  • Anonymous Dec 11, 2008
    erorr 271 date & time
    how can I fixed the erorr
  • 1,605 Answers
Here is the link to a video. how to remove the CMOS battery
Posted on Dec 03, 2008
  • Frank
    Frank Dec 04, 2008
    it is connected to the motherboard.
    look closer. there should be a 2 pin connector near where the battery is placed.
Remove CMOS battery (Large button battery on the main board). Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on
Jul 06, 2016 | Computers & Internet
Were is cmos battery located
removing cmos battery doesnt work no matter how long you leave cmos battery out been there done that , you have to locate cmos jumper on motherboard , remove main battery & memory cards , peel back clearish foil on motherboard near where memory cards install , should see jumper points on motherboard , take bread tie touch jumper contact leave main battery out stand up like book plug in power adapter , and turn on only until boot screen then shut-off , install memory card , remove jumper and try starting laptop , if it hasnt cleared password , remove memory cards and try jumping it again
Mar 07, 2014 | Acer 4220-2346 Notebook
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
Acer aspire laptop battery replacement
Jul 24, 2013 | Acer Aspire 5100 Notebook
Dell d340. need to enter admin password in bios to reorder boot sequence to accept usb first - its locked and i cant remember password. tried removing cmos battery and replacing but no good. help!
Try the backdoor password Dell
With a PSWD Reset Jumper Step 1Open the access panel to the password reset jumper if your Dell laptop has one. Consult your manual for the access panel's location. Some access panels have a tab you slide, while others are held in place with a screw.
Step 2Pry the plastic cover off the reset jumper with your fingernail. The reset jumper is a small pin port labeled "PSWD" with three pins. Put the plastic back onto the jumper over pin 1 and 2 instead of 2 and 3. Wait 90 seconds.
Step 3Pry the plastic off the reset jumper again and place it back onto the number 2 and 3 pins. Turn the laptop on. Repeat step 2 if the password is still present. Leave the plastic clip on pins 1 and 2 for a longer duration than last time.
Without a PSWD Reset Jumper Step 1Locate the reserve battery, also known as the CMOS battery, if your Dell laptop is not equipped with a password reset jumper. The CMOS battery's location varies among Dell laptop models. Consult your manual for the battery's location on your specific Dell laptop model. Many Dell reserve batteries are located underneath the main laptop battery. Remove the main battery and look for a sticker under it with instructions on removing the secondary CMOS battery.
Step 2Remove your Dell's reserve battery per the instruction manual or sticker located under the main battery. Removing the reserve battery resets the laptop's BIOS password. Wait 90 seconds, then replace the reserve battery. Reconnect the main battery.
Step 3Press the "Power" button to turn the laptop on.
Here is some youtube video with your problem:
Try also to call dell support in your country
They will be glad to help you out.
Good luck
Nov 08, 2012 | Dell Computers & Internet
The battery charge light shows green, but the screen is black and no boot. How do I get to the CMOS battery? THANKS.
Hi cqs2000.
Do the following:
"To "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}.
  • paul7of9_182.jpg Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
paul7of9_181.jpg Replace the "CMOS battery."
  • Next, "Only plug-in the "Power Adapter" into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!"
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 15, 2011 | HP Pavilion xh485 Notebook
I'm trying to enter set up. It is asking for password. I don't have one have do I get in?
You will need to clear the cmos memory. Unplug the laptop from the mains power supply. Remove the laptop battery. Press and hold the ON button for a minute or two to try to discharge any stray capacitance. Now comes the hard part. Locate the CMOS backup battery. This might be easily accessed from underneath, or under the keyboard. If you are unlucky then it will be hidden somewhere not easily accessible. If you provide the actual model number I might be able to find out where the battery is. If you manage to find the CMOS battery, you need to disconect it from the motherboard (or remove it if it is in a socket). Leave the battery disconnected for a few minutes. Replace the cmos battery and put the laptop back together. with any luck the cmos will be reset to default and you will be able to get into the bios.
Feb 20, 2011 | HP Computers & Internet
Removed my CMOS battery, but the BIOS settings won't disable
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this
hope it helps!
Nov 04, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm think pad t30
you need to be techy on this one. you need to open the laptop. before you do that, be sure to remove all source of power (ac adapter and battery). press and hold the power button to drain all excess power. check the motherboard and reseat the CMOS jumper. it looks like a tiny pin. after reseating the jumper, reconnecting power and turn on the laptop.
i hope this helps.
Sep 16, 2008 | IBM ThinkPad T30 2366 Notebook
T30 still won't boot after fan replacement
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Sep 08, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
3,678 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
