Question about ViewSonic NextVision N3760W 37 in. LCD Television
After power-on, screen stays on "Viewsonic" splash screen
The moral of the story: don't mess with things you don't understand.
I got into the "Service Menu" and, while some tweaks are clear, I messed with one that wasn't. I believe it was labeled "freeze frame".
Since, all the TV will do is turn on and stay stuck on the Viewsonic logo. None of the buttons work. To turn the TV off requires the power cord be unplugged.
The TV has been unplugged for over a day and the settings haven't reset.
Obviously this is a software/firmware issue, not a hardware one. I just can't figure out how to do a factory reset without access to menus.
  • 17 more comments
  • CJOttawa Dec 03, 2008
    Regrettably, none of these options work. The TV remains stuck at the Viewsonic logo splash-screen, regardless of what sources are connected.
    I tried the reset combo - disconnect power, hold the "up" and "power" buttons, reconnect power while continuing to hold buttons.
    No luck.
  • CJOttawa Dec 04, 2008
    I called Viewsonic's support line but got no further with the problem. They did give me the service menu code (991) which didn't work as the TV wasn't recognizing any commands.
    They also forwarded my info to "a different department" which is supposed to contact me with a form to fill out to possibly obtain a service manual. I'm hopeful they will and said manual will indicate some other options.
    Does anyone reading this have the service manual for the Viewsonic N3760w HDTV?
    Is anyone aware of a service centre for Viewsonic HDTV's that knows how to reset them to factory settings?
    Sadly, leecom72, it was the 991 menu that got me in to this mess. ;) The TV no longer accepts any commands from the remote.
    No luck getting into the menu. The TV won't recognize the menu button is being pressed, nor any button press on the remote or any combination thereof.
    I tried the "repair service" box but as I'm in Canada, lookup by ZIP code doesn't work. (we use 6 character postal codes)
    Keep in mind folks, this is a LCD *television* not an LCD computer monitor. The "post" test I'm reading about seems more related to monitors, not HDTVs. Source signal has never been a criteria for menu access; I simply can't get into the menu now at all.
    Fixe_You,
    Sadly, leaving it unplugged for a couple of days hasn't solved the issue.
    I emailed Viewsonic... we'll see what they say!
    No paper-clip / pin-hole anywhere on the set. Keep in mind: this is an HDTV, not a computer monitor.
    I'll give Viewsonic Canada a call in the morning.
    emissionwiz,
    I agree with you and have actually called Viewsonic twice now, emailed them once. So far, nada, though I got farther on the second call but still no solution.
    I will try their Canadian number tomorrow though.
    funkyjacob,
    Yes, I've tried all of the remote buttons and all of the buttons on the side of the HDTV to no avail. It appears none are being recognized by the TV.
    This wasn't caused by hitting freeze in a regular menu it was a setting in the service menu.
    rhoncruz,
    No luck with holding those key combinations. Menu and Power buttons still don't work once the TV is on.
  • CJOttawa Dec 05, 2008
    send2shwetha,
    There is no "enter" button on the TV. As previously indicated, unplugging the TV for several days still doesn't solve the problem.
    sintm_112,
    I have inspected every part of this TV. There does not appear to be a reset hole of any kind.
    taran_2005,
    I've tried this procedure already - it's an HDTV, not a monitor, so this function doesn't appear to be an option.
  • CJOttawa Dec 10, 2008
    ndguy2481,
    Nope, I find no reset switch, anywhere on the TV.
  • 148 Answers
Try to download your tv service Guide or manual and try to configure and restore you tv default values in your tv setup...
Good Luck!!!
Posted on Dec 10, 2008
    Genius:
  • 1,061 Answers
Contact viewsonics' support line and they will explain how.RICHARDM69
Posted on Dec 05, 2008
  • 10,594 Answers
The only option left is to replace main board of your Viewsonic N3760W TV and you can try to have main board from Shop Jimmy.
TV is not in condition to communicate with PC for firmware update / flash as you said its stuck on Viewsonic logo screen and all no button works.
    Sergeant:
    Champion:
  • 251 Answers
There is a reset button on the back of the tv near the av hook up use a pen top to reset it
  • 10,515 Answers
1. AC power off (near the VGA/DVI connectors of the monitor)
2. Press and hold the [Up] and [Power] buttons (front panel)
3. AC power on
4. Keeping holding until the message "ALL RESET" appears
C'est tout! Your monitor is fixed. :D
Have a nice day.
  • taran_2005
    taran_2005 Dec 05, 2008
    1. Turn the television on.
    2. Hold VOL - ON TELEVISION and SLEEP on the REMOTE.
    3. When self-check is displayed, press any button
    Try this one :)
  • 109 Answers
There should be a little tiny hole that says reset on it you will need a pin to reset it so try that one..
Posted on Dec 04, 2008
  • 51 Answers
With the TV powered on, hold the Menu and Enter buttons down together, then press the power button. This should correct the problem. If not unplug the TV and leave it off for an hour or more. This will reset the TV back to the factory options. If neither of these solutions correct the problem please let me know. I believe the menu+enter and then off will stop the problem.
    Genius:
  • 1,239 Answers
Hi i think it is better to change the firmware of yours..i read all the comments from you and other members..actually there may may be trouble in the screen .,.and there are many code functions for it....so it is better to go to a tech rather to contact customer care.. thank you...
    Scholar:
  • 134 Answers
You can try this
after power-on, screen stays on
Or download the manual
Try this link
http://www.viewsonic.com/assets/031/8576.pdf
I hope it helps!!!
  • 734 Answers
When u have tried so many things....try for the last time replacing your remote's battery with a new one and then hold the power off button on the remote for 30 secs and then try restarting ur tv.....hope it works
thanks
  • futureloginn
    futureloginn Dec 04, 2008
    the bios in ur tv needs to be reconfigured. it can be done by two ways:
    a) either the same bios can be reconfigured , or
    b) bios can be replaced
    thanks
  • futureloginn
    futureloginn Dec 10, 2008
    the bios in ur tv needs to be reconfigured. it can be done by two ways:a) either the same bios can be reconfigured , or
    thanks
  • 76 Answers
All freeze frame is that it takes a snap shot of the picture and freezes it. They use it in most projectors so that people can freeze at a picture or chart in a conferance or at schools.
You should be able to change the setting which is on your remote it should say freeze or snap shot or something like that.
Once you have done that it should continue normally
have you tried the buttons on the tv not using the remote?
If you have any questions please dont hesitate to ask
    Guru:
  • 558 Answers
Its human tendency to know what is new and latest. This fascinating to every human being, so dont worry about it.
This problem can be rectified in a simpler way, just wait and relax. You are at right station to get it fixed.
Just check the TV with all its cable and replug it to power. Make your remote battery replace and then try it again.
    Sergeant:
    Champion:
  • 283 Answers
Hi,please dont rate me if could not fix your problem. Check the front panel of your unit.check the keys if there is any pads that stuck. Thank you...
    Sergeant:
  • 237 Answers
  1. To reset, take a paper clip and push it into a pinhole next to the power button(or close to).
  2. Hold for 30 seconds and turn the power back on
    President:
  • 2,712 Answers
Looks like the EEPROM chip is busted. you may have to get it replaced.
You can find a repair center nearby by entering your Zip code in the box to the right marked "REPAIR SERVICE". that will throw up a list of service centers in your area. Mention you were refered by Fixya, and you just might get a discount :)
  • Swilin Sampson
    Swilin Sampson Dec 04, 2008
    Well number for Customer Service in Canada is 866-463-4775. Maybe they can help..
  • 4,806 Answers
There are three pages of "secret" menus accessed by pressing 9-9-1 on the remote control. These are esoteric settings such as film pull-down adjustments and S-Video auto-detect. Not for novices - you could really mess up your monitor! Fortunately there's a factory-reset in these menus to correct any damage you inflict on your TV. The only way to leave the secret menu is to turn off the set. Then turn it back on again.
hope this works and kind regards
Posted on Dec 03, 2008
  • Lee Hodgson
    Lee Hodgson Dec 04, 2008
    You can email them see what you can do about this as i cannot find a hard reset on the tv itself. I think your initial suspicions were correct and the fimware has become corrupt. contact them here:
    http://www.viewsonic.com/support/custome...
    kind regards
  • 1,800 Answers
Hi.
as Mr.Gink said the memory of ur unit shud get a flash.
this freeze parameter now is stuck in ur memory and the memory shud be flashed while giving the unit a new OSD Firmware.
but the bad news is Viewsonic isn't a major brand so the Fix in this case is rare, especially the upgrading/flashing memory case.
one thing that u can do in this case is to take it a part and replace the memory with a well working one or even take the memory chip to someone that can handle this cases like flashing BIOS and flash memories.
good luck.
Thanx For Using FixYA.
  • Jalal Sordo
    Jalal Sordo Dec 04, 2008
    try to let the tv get a rest for 24 hours without power cod on outlet maybe that will erase the prob from mem
  • 3,037 Answers
How long have you had this tv? If it is under warranty, see if Viewsonic will check it out for you and even if it isn't. Otherwise they may also be able to suggest what you can do or send you any kind of firmware update. Give them a call and tell them you want to speak to a service technician at (800) 688-6688 as they probably have a quick fix for it or at least can give you better options if nothing else after you have tried the other experts' solutions as I have nothing to add to them. Let me know what you find.
    Master:
  • 474 Answers
Before i get into detail, try this, it may just be this and easily solves.
Make sure it connected to something thats known to be putting out a signal like a P.C. or T.V.
Then turn on the monitor and pres each button once and see if you get anything.
Also, what type of connector does it have. VGA or DVI or a DVI adapter to fit it onto a VGA video card.?
What im thinking is that it may be stuck in DIGITAl or ANOLOGUE mode and whats its connected to is the other.
Also, try only plugging in the power cord but not the video or data cable and se eif you get a POST check.
( GREN RED AND BLUE bars indicating it works but has no signal.)
If this comes up, see if you can open the manu now. Allthough some models wont let you till the signal cable is attached.
Just give this a shot and get back if no results and we can try something else.
Good Luck
  • Chris Busch
    Chris Busch Dec 04, 2008
    Well, my friend had a similar problem with another brand and he was told that it had some internal hardware issu and would not POST at all and just show the splash screen.
    If you power it on and your not getting the POST then more than likely its a gonner. But as long as you have it, dont give up. As a last result, you could open it up and inspect any copacitors and chips for signs of damage such as swollen capacitors or a distinct burt smell or just burn marks around any of the chipsets.
    You can use a cotton swab and some alcohol to clean the boards and circuitry. Unplug and disconect it first of course.
  • Chris Busch
    Chris Busch Dec 05, 2008
    When the screen comes on, try pressing different combinations of buttons.
    The option you selected, FREEZ FRAME, bassically freezes the image and doesnt change untill its turned off, Why it wont turn off after unplugging it is strange, it may have an internal battery that olds the setting.
    Like a Bios battery. You could try opening it up and removing it.
    Just a thought, good luck
  • ViewSonic Master
  • 19,396 Answers
Did you try first unpluggign the power cable, that should reset the freeze mode.
  • 3 more comments
  • Ginko
    Ginko Dec 03, 2008
    Sorry I missed the line that said you had unplugged already, Viewsonic is not a big brand and screen may be re-manufactured. I dont have the service manual, I can see what I find on the internet , and post on the next few hours.
    If there is no reset, and the firmware had been damaged, you will need to to have it reflashed at a repair shop, I dont think firmware for this unit is available on the internet.
  • Ginko
    Ginko Dec 03, 2008
    There is a "Memory recall" option on your TV to set it to default factory settings, see: Viewsonic Reset
  • Ginko
    Ginko Dec 03, 2008
    Before trying the memory reset, do the following , is a general reset procedure for Viewsonic LCD monitors , it should be the same on TVs:
    1. Turn theAC power off using the switch at the back of the tv if present, or unplug power cable.
    2. Press and hold Up and Power buttons on the front panel
    3. Turn the AC power back on, or reconnect the cable
    4. Keep holding the buttons until you get the message "ALL RESET"
    Let me know how it goes.
  • Ginko
    Ginko Dec 03, 2008
    See if you can call the menu, if you can call the menu there is a Setup >>System Reset option.
    You could also try entering in service mode, be aware that in service mode you can cause more damage, this operation should be done by a repairman.
    I think you enter the service mode menu then
    4,7,2,5.
    If nothing work, there is a firmware upgrade and service port at the back, that must be connected to a computer, with specific software. That can be done only at a repair shop.
  • Ginko
    Ginko Dec 04, 2008
    You reste the freeze option on Servce menu by unpluggign power. What you are experiencing , it is not the freeze option, that is used on service menu to do diagnostics, and is only temporary.
    What you have is the computer not starting because the firmware had been collaterally damaged when using the service menu (probably turning TV off while a command was being executed).
    The TV must be connected to a laptop to the service port at the back (on some model you use the 15 pins VGA), and firmware installed from image disk, same as a BIOS upgrade.
    You can call Viewsonic, and ask them if they can send you a copy of the disk, and the cable. Usually this kind of software is distributed to licenced repairs only.
    If Viewsonic does not distribute the software to non repairman, the only way out , is finding a not-too-expensive repair shop, and ask a quote for a firmware upgrade of this kind, in UK we charge 50 pounds or so for this job.
    Top Expert:
  • ViewSonic Master
  • 70,387 Answers
I have no idea why you don't call the manufacturer tech line for your TV, they will know what to do instead of just guessing like all the experts are doing here so far. I have used many product tech support services, they have always solved the problem for there product.
  • yadayada
    yadayada Dec 04, 2008
    Good I hope they can get this resolved for you
1983 yamaha venture royale 1200--- no power on high end. runs great at idle and going thru the gears up to 50mph then sluggish after that. changed the air filter, gas filter, plugs and brand new non...
good maintnance what you did. but these bikes lacked power in high gear and I used to always have to gear down and pick up more spead. remember that they are a touring bike so you shouldn't even be in 5th at 50mph. try this build enough speed and stay in 4th and don't go up to 5th unless you hit at least 60mph or a bit more. I have an 04 now and guess what, they are all the same you gotta build enough speed before 5th, I toped the 110mph on mine just last week. moral of story, don't treat them like normal cruisers, stay in 3d gear when around town. 4th is just as you get on the freeway and 5th is only for freeway.
I hope this helps.
Apr 29, 2011 | Yamaha Royal Star Venture Motorcycles
Have open the diesel model DZ9004 and replace both battries, and unable to reboot the digital seconds count on dial. any idea how to get it started?
I had same problem at watch makers and the put the old battery back for the digital secnods count and it started working. I guess the moral of the story is don't replace the digital seconds battery.
Nov 08, 2010 | Diesel DZ9004 Watch for Men
Viewsonic has trouble turning on-- seems to backlight (screen lights, makes an electronic hum), and then go to dead (yet the green power indicator stays on).
Hi, well if this is the inverter board, then its probably more cost effective to buy a new screen, same thing if this is the cathode lights. Reason for that is the technician will charge to replace, so cost will get anywhere from 50 and up. Only one question, how many years old is it? I do believe Viewsonic has 3 year warranties.
Nov 01, 2009 | ViewSonic VP171B (Black) 17 in. Flat Panel...
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
VA930 LCD Screen goes black blank
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
If you need more help, let me know.
Apr 07, 2009 | ViewSonic VA1930WM LCD Monitor
My biewsonic va702b, when powered up flashes for one second the screen. it's bright in all the corners, just wont stay on, power light changed to orange. do I have inverter problems??
The power light turning orange means the monitor isn't getting a signal from the computer. Or the monitor has a problem. If the screen shows light in the corners, the inverter is working. (If the inverter stops there is no light at all.)
The first thing to try is connecting another monitor to make sure your computer is actually starting up. If that monitor also shows nothing, you have a computer issue to take care of. Otherwise the monitor needs service.
Mar 03, 2009 | ViewSonic VA702B 17" LCD
Computer loading/splash screen pixilated and distorted
if you can, hook the computer up to a different monitor and see if it does the same thing. It sounds like it is an issue with your monitor initalizing but the reboot can complicate things. Also if you have a cd that came with the computer you might want to put it in and see if you can re-install your video drivers. One last thing is to check and see if the reboot might have changed some of the settings on the monitor itself. See if you can reset to factory default or an auto adjust. It depends on the kind of monitor as to wich option you can do
Jan 02, 2009 | Computers & Internet
Viewsonic monitor VG2021m won't awaken
I understand the vg2021m has a 3 year warranty. Phone number for Product Support is (800) 688-6688. Give 'em a call and see if they won't fix it for free or some nominal charge. (OK! So this is the cowards way out.)
Orval
Oct 05, 2008 | ViewSonic Graphic VG2021m LCD Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
ViewSonic NextVision N3760W 37 in. LCD Television Logo
344 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
