Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
My washer is full of water and wont drain or spin
I pull the timer knob thingee and it makes sound like it wants to bigin spinning or something but doesn't. Can you help me figure out if I should replace this washing machine or not. By the way, Maytag Ensignia Super Capacity Plus
  • spys_eye Feb 08, 2009
    My maytag ensignia will not power up. Its full of water. I unplugged then replugged the power cord. The socket is good, but the washer does not respond to any cycle command. No lights come on. Its like its not receiving power. What is the problem, PLEASE
  • 734 Answers
Hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My washer agitates drains but wont spin until i manipulate the switch to wash make it agitate fo a couple of seconds than switch it to spin cycle than it spins
sounds like your timer is bad this is the selector for spin wash ect... This is not a hard repair the back comes off the back top of the washer to exspose the elect controls you will need to unplug it then pull off the knobs and remove the two screws. Make sure to unplug the unit from electricity first. good luck.
Aug 10, 2010 | Maytag SAV2655A Top Load Washer
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    May 01, 2010 | Roper RTW4300SQ Top Load Washer
    My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
    Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
    Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
    Jan 16, 2009 | Kenmore 22422 Top Load Washer
    Washer not spinning - not timer
    I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
    Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
    Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
    459 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
