Question about Motorola Mobility RAZR V3i Cellular Phone
No information on external display
The external display shows only the Motorola logo. It's the same whether the phone is open or closed. Can anyone tell me how to restore the display of the time, phone status, incoming calls, etc.
    Brigadier General:
  • 7,752 Answers
You have a magnet in the top of the housing that is loose it is needed to make the motorola display works....so you can take it to a mobile service center and have them fix it for you.
Posted on Dec 28, 2008
Hello on moto razor v3i 's external sreen only moto logo is displayed , need help, it doesn't show ordinary information.
pull the battery, let it sit for a few minutes, then replace it and power it back on. If that doesn't work its likely a physical defect with the phone and not a software glitch. these can be easily replaced online for under $20 if you look :0)
Mar 03, 2011 | Motorola Mobility RAZR V3
I can see just a logo on ma moto v3i's external screen
Remove the battery, wait ten minutes and put it back.
Try also removing the sim, try a different one if you have it.
If you have a memory card start it without the card inside.
Try also the following procedure:
"press and hold the * # andpower button all at the same time until you see text come up on thescreen. If you get the text on the screen, pull the battery out, pressthe power button three or four times to discharge the phone completelyand then try the battery again and hold the power button for 8 secondsor until the blue in the kaypad gives a slight flash dim"
from HowardForums
Check also here
Motorola v3m razr has frozen up - FixYa
If it still does not start it is faulty, take it to a repair shop.
Sep 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
External display
you can try and do a master reset and master clear that should fix the issue.
Jan 08, 2008 | Motorola Mobility RAZR V3
Razor phone external display
I had the same problem. I sent it back to Motorola for warranty. They fixed it and said it was a connection issue.The connection between the screen and the keys came unplugged. This is a regular problem they have with this phone. The phone is poor quality!!!!
Nov 21, 2007 | Motorola Mobility RAZR V3
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Motorola V3
You may have improperly closed the phone when you changed the cover............and messed up the flex cable that connect the display to the main board.
Jul 08, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3m External Display Problem
Ive had 2 silver razrs and my first did the exact same thing it's a sensor intenally that wears out ecspecialy on the silver ones dont ask why? But i sent my back and replaced it. If you pay insurance everymonth like me use it!!
Jun 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
97 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
