Question about Gateway 2520915 Keyboard
Download music Downloaded some free music files. Then I got a pop up selling a registry repair. Then my sound insertions in a slide show stopped working. So I restarted the computer and it went into some DOS mode to deal with corrupted files. I figure I should uninstall all the free downloads, or delete them if they are just files but now my keyboard does not work and it is not the keyboard's fault. I checked it in another computer and checked other keyboards in it.
    Novelist:
  • 115 Answers
I hate to tell you this, but it sounds like you downloaded a very bad virus as well.
First, boot the computer while holding down the F8 key. Continue holding this key until the screen changes. Use the arrow up key to boot in 'last good configuration that worked. Immediately open control panel, then click on performance and maintenance, then in the left column 'system restore'. Choose 'restore my computer to an earlier time' and pick a date before this happened.
If it is successfully restored immediately download a good anti-virus, update it and run it ASAP. I strongly suggest AVGfree 8.0 from filehippo.com. Until you do this the virus is still in your computer and eventually will cause further problems. Good Luck!
Posted on Dec 03, 2008
HOW DO I LOOP A SOUND FILE TO KEEP PLAYING TO THE END OF THE SLIDES WITHOUT EXTENDING THE TIME OF EACH SLIDE?
1) File > New > Presentation > Create (new presentation with all default settings)
2) Panel at right: Slide Transition > Modify Transition > Sound = "apert" (fourth in the drop down list)
You should hear a short (~2s) sound at this point, as the effect is "previewed". If you don't hear it, try the "Play" button at the bottom of the Slide Transition panel. If that doesn't work, then OOo is not able to play sounds and you have to fix that before proceeding.
3) Slide Transition > Modify Transition > Sound = "Other sound" > (select your long music file).
You may or may not hear the preview for this, it depends on whether your music file has a quiet leader at the beginning. If the audio starts right away, you should hear it. If the audio starts after 1-2s of silence, you won't hear anything.
4) Click "Slide show" (bottom of the Slide Transition panel) or F5.
You should hear the music start. It will continue to play even after you advance to the next slide (which is the black "End of show" screen. Advance again to end the show and the music should stop.
Jul 29, 2015 | Computers & Internet
Registry usb
Yes, transferring data files from your expansion drive into the computer or from the computer into the expansion drive can make your computer run slowly.
If it's music and/or movies you are transferring back and forth it's simply because the computer is using most of the processor speed and memory to do it. That's why when another program or the internet is opened your computer will appear to run slowly.
If it's just slow in recognising the contents of your expansion drive it may be due to the age of your computer.
Alternatively it may be that your computer and/or expansion drive is fragmented and has registry errors. Both of these will cause - can cause - your computer to appear slow to load.
You can defragment your hard drive from within the computer. Using Windows XP, open 'my computer' andright click on the 'C drive icon' icon and then choose TOOLS. Open the defragmenting software and let it defrag the hard drive.
To fix registry faults search for and download some free software called free Windows registry repair. http://download.cnet.com/Free-Window-Registry-Repair/3000-2086_4-10606555.html
When downloaded, run the registry fixer by opening the program and click on 'scan'. Wait until the scan is complete and click on 'fix'. Job done...
Jun 09, 2013 | Seagate Expansion Computers & Internet
Music in power point presentations
  1. Display the slide to which you want to add music or sound effects.
  2. On the Insert menu, point to Movies and Sounds, and then do one of the following:
za079005000.gifInsert a sound file
za079005000.gifInsert a sound clip from Clip Organizer
  1. Double-click the sound file that you want to insert.
  2. When a message is displayed, do one of the following:
    • To play the music or sound automatically when you go to the slide, clickAutomatically.
    • To play the music or sound only when you click the sound icon za006052183.gif, clickWhen Clicked.
  3. To adjust the settings for when the sound file stops, click the sound icon za006052183.gif, right-click, and then click Custom Animation.
  4. In the Custom Animation task pane, click the arrow on the selected item in the Custom Animation list, and then click Effect Options.
  5. On the Effect tab, under Stop playing, do one of the following:
    • To stop the sound file on mouse-click of this slide, select On click (the default).
    • To stop the sound file after this slide, select After current slide.
    • To keep the sound file playing for several slides, select After, and then set the total number of slides the file should play on.
Mar 24, 2011 | Microsoft Windows Vista Home Basic Edition
I made a powerpoint presentation with PP2003, first added 6 slides, then added another 20. When I add music to the presentation, the music stops at the 6th slide. HELP!
To make a sound continue through multiple or all slides, follow these steps:
  • Go to the slide where you want to begin your audio track (defaulted as the first slide), and select Insert -> Movies and Sounds -> Sound from File to insert the sound.
  • After you click OK, you can see a message pop up asking how you want the sound to start in slide shows. Click Automatically.
  • Select Slide Show ->Custom Animation to enter the Custom Animation pane. Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slideshow if you don't want it appear.
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
Jan 16, 2010 | Microsoft PowerPoint 2003 Student &...
Play sound from music files, video files and DVDs,
thats not a hardware problem your speakers are fine sounds like a codex problem try downloading VLC free
and also put the downloaded audio on a pen drive and see if it will play on another system the files you downloaded may be corrupt
Dec 02, 2009 | Logitech Z4 Speakers
How do you upload music from pc to dsc-W130 camera
You can use your usb cable that came with the camera or you can insert the card into the computer, and downloaded onto the card. Once on the card, then you can show your slide show, by insert it into the camer.
Nov 29, 2009 | Sony Cyber-shot DSC-W130/B Digital Camera
Synchronize to continue your music subscription
I ran into the same problem with my Sansa when listening to legally downloaded audio books from the local library. This is what I found:
  • " Are you sure the player is in MTP(plays for sure) mode when you transfer it? You can check by going to settings>usb mode on the player itself. I think it needs to be for you to use library files like that. " (This worked for me)
  • "are you copy and pasting the files? if so you will need to use WMP to sync the files. copy and paste might not be transferring the license." (didn't try this -- didn't need to)
Hope this helps.
Nov 26, 2008 | Audio Players & Recorders
Adding music to a powerpoint presentation
Does the music file play when you click on it? (Drag the sound icon someplace visible on your slide and preview it.)
If it does play when you click on it, you just need to animate the music. The sound file has to be a part of your slide animation--that's what tells it when to start/stop playing. When you insert a sound file, PPT may ask you whether you want it to start automatically or wait to be clicked.
Or, you can right-click an existing sound file and go CUSTOM ANIMATION. Depending on your version of PPT, what happens next will be different. But you should be able to set the sound file to play when the slide displays without being clicked.
Dec 03, 2007 | Computers & Internet
Ipod shown in recovery mode when plugged into new itunes version
Each iPod usually only syncs up to 1 computer. try downloading a program called idump. It allows you to take all of your music and files off the ipod and onto the computer, without having to restore. Then you'll have to restore the ipod, and put all the songs back onto it.
Oct 29, 2007 | Apple iPod nano
Using powerpoint to add music on slides
i want to edit music on my slides. i want one track/sound to play through all slides
Oct 23, 2007 | Microsoft Office Professional 2007 Full...
Gateway 2520915 Keyboard Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
