Question about Microsoft Xbox 360 Console
Audio but no Video
I have just purchased A 360 on ebay, and upon hooking it up I can hear the audio, but no picture at all.
  • 72 Answers
Might be the componet cables... but some consoles have alot of heat sink compond and when the system gets to hot it runs down onto the mobo... If you have tryed everything else and the system is not under warranty open it up and check to see if this is the case.
Posted on Dec 04, 2008
I hook everything up to the tv for the nintendo 64, but I still have no picture on the tv or audio. Help!
make sure your cords are in properly. You may have to get a new set of cords from ebay or your local electronics store. Also NOTE: Most TV's have AV1, AV2, Component, then Cable. AV1 and AV2 are both ports(usually on the sides and back), thatyou plug the audio and video into. Make sure both of these have no video or audio before you go out to purchase new cords.
Hope this helps!
Aug 09, 2010 | Nintendo 64 Console
Whenever I try to connect dazzle it says.... failed to get video from device. It is coming from an xbox 360. and I know that xbox works with dazzle and pinnacle. I hooked it up all right.
donwload amcap
on amcap click
options
video capture filter
video image
tick the boxes
ext audio and usb audio
then go back to video capture filter
on video decoder
change the video to ntsc _433
then you will have audio and black n white picture then
change ntsc_433 to secam_B
than load pinnacle then capture/import
then you will have picture colour audio
Aug 01, 2010 | Pinnacle Video Transfer
I can hear the audio but I can't get a picture
Some x-box 360 cables have a switch on the end that inserts into the 360 console. It switches to HD TV if you have one. If it is switched to the wrong TV type you will get no picture.
Try a different cable or HDMI cable if the 360 had HDMI.
If none of the above work its probably 360 mainboard. Easiest fix would be to replace it or exchange if it has warranty. Good Luck
Nov 23, 2009 | Microsoft Xbox 360 Console
How to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Mar 14, 2009 | Bose 3·2·1 II System
Audio works but the video is scrambled
I had this problem when I used my 360 on a new projector, its because the video setting on your 360 is set to 60Hz, and your display can only support 50Hz, you should still be able to see the picture enough to change the setting, but most games will now not work, so yu will really need to buy either;
- The VGA (like what PC'a use + audio) HD Cable
- The Component (a yellow, blue, green and red plug + audio) HD Cable
- The Advanced SCART Cable
or you can connect the standart composite cable (one yellow plug) to an RF modulator and use a coax (arial) connection, but this will give pretty dire quality.
Jan 02, 2009 | Microsoft Xbox 360 Console
Philips 1080i xbox 360 hook up
you need to change the settings on the xbox aswell.
go to your settings menu and change the picture settings to 1080i
Oct 27, 2008 | Mitsubishi WS-55857 55" Rear Projection...
360 hook up
Explain how your cables are hooked up, especially the cables for
video and maybe I might be able to offer help.
richard
May 22, 2008 | Denon AVR588 Receiver
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
