It's a 3D BLU-Ray player with Internet Apps VBR133
Http://maxdalton.hubpages.com/hub/Troubleshooting-Vizio-VBR133-Blu-Ray-Player-Problems
"Internet Apps Problems
If you're experiencing problems with the Internet apps that come
pre-installed, such as Netflix, Vudu or Pandora, check the website
belonging to the company operating the app to see if the service is down
or if there is a way you can contact the company to ask about the
issue. Alternatively, try restarting the Vizio VBR133 Blu-ray player to
see if that resolves the issue."
HTH
GSS
SOURCE: unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
SOURCE: how to hook up insignia blu ray player to netflix
This model player (NS-BRDVD) is not Netflix capable. Netflix capable models are NS-BRDVD3, NS-WBRDVD, and home theater system NS-BRHTIB.
SOURCE: LG super blu player won't play blu ray disc
Have you updated the firmware on it? I had a similar problem with a Sony blu-ray player and I had to download an update and burn it on to a CD then allow the CD to update the blu-ray player. What's the model number of your player, I may be able to get a link to the update for you.
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck [email protected]
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
