Question about Canon PIXMA MX310 All-In-One Printer
Can't scan!!! Canon MX310
I've scanned with this printer before..for some reason it's not working now. Everything is plugged in & turned on. The error message reads:
Cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check Status. Scanner driver will be closed.
Has anyone had this problem? Thank you.
  • Anonymous Dec 17, 2008
    Canon MX310 Cannot communicate with scanner
  • Anonymous Jan 04, 2009
    I have the same problem...wondering if you ever got a solution.
    Thanks!
  • 46 Answers
SOURCE: scanner error
if you put the installation cd in the drive and then if it autostarts close it down, then go to device manager and the properties of the scanner and update driver let pc search automatically and it should reinstall it and then all should be fine i hope , had the same problem on my all in one device
Posted on Sep 24, 2007
SOURCE: error 21550 pixma mp160
I found a solution for this problem
change your usb cable.
you must use a Anti noise usb cable
it's only solution
Posted on Nov 19, 2007
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Posted on Mar 09, 2009
I am unable to scan on my canon pixma mx310, i can print but cannot scan
same problem I think. Unplug all conections and power to printer
Uninstall print software...reboot...up date at windows update site.. make sure u have the latest installer which is 4.2(windows installer)search it with google if ur not sure...reload as if it were new..software first then printer plugs
Nov 29, 2009 | Canon PIXMA MX310 All-In-One Printer
My Canon MX310 will not scan pictures -
it sounds like a file is corrupt,if you have a driver disk,delete everything and redownload it.a file might not have copie right the first time.
Jun 09, 2009 | Canon MX310 Office All-In-One Printer
How do you scan a photo?
- press "scan" button, then press "start" button (either black or color)
- a small window (MP Navigator EX - MX310 series) should appear on your computer screen
- you can then choose one of the option there
- place a document or photo you want to scan on the canon plate face down
- then back to your computer screen and click "scan"
i have iMac and the pop up window says (MP Navigator EX - MX310 series) when i press "start" button on Canon
now i'm not sure if it'll say (MP Navigator EX - MX310 series) on windows PC
hope this helps. good luck.
Feb 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Scan function won't work with Mac OS10.5.5 & Airport
I plugged the printer cable directly to my laptop instead of trying to scan using the airport wireless router. Plugging it in did the trick.
Thank you,
Jtoussa
Nov 22, 2008 | Canon PIXMA MX310 All-In-One Printer
I can not scan
YOu may want to reset the printer and try to scan again. If this is not succesful you have to make sure your printer have the correct driver with the correct OS. You may want to read below link to resolve your issue.
http://etech.maiila.com/canon-pixma-mx310-driver-manual-software-download-and-troubleshooting-tips
Good Luck..
Please dont forget to rate me..
Nov 07, 2008 | Canon PIXMA MX310 All-In-One Printer
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Can feature not working
I fixed it by reinstalling the printer software and downloading the driver for the scanner. Worked like a charm!
Apr 13, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
623 people viewed this question
old marine
old marine
