Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE3t Front Loading Washer
I ran a cycle before bed and the machine seemed to run forever. This morning I found the door won't unlock. The "controls locked" button is lit. I attempted to run another cycle to clear the problem and found the drum doesn't turn and the motor sounds aren't the same as usual. Unplugging the machine does not correct the problem. I have a repairman coming in the morning. I have no idea what is wrong or how much repairs will potentially cost. Question: Would it be reasonable to spend $280 for a one year extended warranty that will cover the cost of the repair I have scheduled or is the warranty cost too high in relation to what my repair bill will likely be outright?
    President:
  • 1,294 Answers
Try holding 'end of cycle' button for 3 seconds. If not........
  • Door Lock Mechanism broken or removed from the door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If you get the door to open try some WD40 on the door mechanism, not on door, and open/close a few times. "Plug should be off the wall" when trying this, and tinkering inside machine, caution.
Posted on Mar 13, 2009
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F9 for kenmore elite washing machine He3T
it will not let you unlock the door because the machines full of water?--the machine will not finish its cycle because the vacume switch is still detecting water , The water will not drain because the pump is blocked with something , probably a wire from your underwire bra,all you can do is undo a pipe undernieth and let the water drain away and take the pump to bits ?There may be an inspection cap somewhere on the front at the bottom
May 23, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Our Kenmore front loading washing machine HE3t has never had a problem until this morning. We tried to start a load and the machine is showing an error message ''dL'' followed by an ''F''. In the booklet,...
i replaced to door lock, and while I was at it the hinges and door lock latch.
this solved the problem. i found it had worked loose by leaning on the door.
you can find the parts at various vendors on the internet if you are handy to replace them yourselves. or call in a tech. i think the parts were under a $100 in total.
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't start; has alternating "dl" and "f" errors....can't reset
This is a Door Lock Error. The service manual lists the following causes: Door Lock Mechanism is broken or removed from door. Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this). To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Oct 28, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
265 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
