Question about Sakar 62150 Keyboard
Manual Where's the manual for the 62150 wireless keyboard? The "Keyboard Control Center" has two rows of seven buttons each and a third row for two more buttons. ummmm that's 16 buttons on a 15 button device and three of the 15 are "Sleep", "Wakeup", "Power" which, while self evident, doesn't explain the purpose of or the whereabouts of 4 of the buttons that the configuration utility aka "Keyboard Control Center" implies exist.
  • Is there somewhere where you can download a manual for a Sakar Model 62150 wireless mouse & keyboard?
    All of a sudden I am having major problems, with the mouse not working....I actually had to switch back to the "wired" keyboard & mouse...
    Thanks in advance
  • Anonymous Feb 21, 2008
    I have a new computer but have lost the manual on connecting the wireless keyboard and mouse combo #62150. Can someone help?
  • 117 Answers
ahamed100
  • 148 Answers
SOURCE: wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Posted on Mar 02, 2008
SOURCE: Computer not recognizing Keyboard, only Mouse
I'm having the same problem. Mouse works great but the keyboard doesn't. I've uninstalled and reinstalled the software at least twice via remote desktop- done a hard reboot on the hardware (it's a Logitec wireless keyboard) - I've even tried installing it on another computer and the keyboard and mouse both work great! I just can't get it to work on my computer. The curious thing is that the side buttons (like sleep work) but it won't Ctrl Alt Del so I can login - what am I doing wrong? Are there settings that need to be changed?
Posted on May 10, 2008
  • 5 Answers
SOURCE: 62150 keyboard and mouse
From what I remember reading the manual, press ID button on the receiver. LED on receiver will blink fast for a few seconds then slower. Press ID button on mouse and keyboard (need a pen or something to press mouse button). I've never had a problem syncing the keyboard/mouse no matter what order I do them. Never had a problem till new computer (USB/PS2 separate ports) and Win7. Now keyboard works, but mouse will not respond though receiver LED blinks it is receiving input. I will try an adapter and go all USB.
Posted on Jun 20, 2010
  • 5 Answers
SOURCE: how to reset keyboard?
Press the ID button on the receiver. LED will blink fast for a few seconds, then slower. Press the ID button on the keyboard and mouse (need a pen or something for the mouse button). Always works for me no matter which order I do them in. If receiver LED blinks whenever you mover mouse or hit key, it is receiving signal. (remember mouse sleeps after a few minutes and you have to spin the scroll wheel). If OS does not recognize on new computer, may be connectors. I had separate keyboard and mouse PS2 ports and had to use an USB adapter for the keyboard cable.
  • 5 Answers
SOURCE: mouse works fine but cant get keyboard to sync
There is a PS2 cable which I connected to the PS2 keyboard port on my mainboard, and an USB connector which I used an adapter and connected to the PS2 mouse port. After getting a new system with only one PS2 port, I found out the USB connector will run both the keyboard AND mouse. You don't need to use the PS2 cable if you have an available USB port. I was running XP Pro before, now I'm running Win7. Works fine for me with only USB cable.
Why doesnt the third row of keys on my keyboard do not workk
The keyboard itself is defective. The keys are "strung" together in groupings. The T just happens to be on another string then the top row.. To verify you can easly hook up an external keyboard and verify that it works. Once verified it all works then the problem itself will be in the keyboard. Replace the keyboard. You can easly find them online and are not that expensive or hard to replace.
May 15, 2014 | HEWLETT-PACKARD ProBook 6460B
Where is the switch located on the computer case
Hi snetaps3,
If you look just above the keyboard on the right-hand side you will see a row of buttons. The Power button is the button on the far right of the row. The other buttons are quick launch buttons.
If you need a manual for your laptop, I have located one in the link below. When clicked it should enable you to download a zip file. In the zip file is the pdf manual. The page showing the front view of your laptop is on page 29.
http://global-download.acer.com/GDFiles/Document/User%20Manual/AS5550_3670-ENG-OLM.zip?acerid=633646623289370172&Step1=Notebook&Step2=Aspire&Step3=Aspire%205550&OS=X01&LC=en&BC=Acer&SC=EMEA_27
I hope this has been helpful for you.
Kind Regards
mparkyn
Jul 27, 2011 | Acer Aspire 5500 5570-2609 Laptop
I conect zte modem with laptop . laptop is shown runtime errer
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Aspire 4520 - Above keyboard right below the power button, the far left one is the wireless button
Aspire 5310/5315/5710/5710Z Series - Row of switches above keyboard deck, left most switch
May 28, 2011 | Computers & Internet
How to reset keyboard?
Jan 05, 2010 | Sakar 62150 Keyboard
On the third row of my keyboard(Aspire 5515), some of the keys of my keyboard do not work. ex. on the QWERTY row - letters Q, E , T ...work, but W, R, Y....do not work.
Hi:
laptop keyboards are somewhat fragile, and fail quite often.
An easy solution is to replace the keyboard, about $15 on ebay. They are not too hard to change, and a solution in the meantime is to use an external USB keyboard too.
Oct 25, 2009 | Computers & Internet
Recently replaced drivers and the top row hot
if you go into ctrl panel to system..hardware..device manager..select your keyboard from the list and you should be able to roll back the driver
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Bought two Sakar I Concepts wireless keyboard/mouse last summer at walmart and kept them to give as Christmas presents. I have found out from both people that I gave them to that the mouse works on both of...
I've used the 62150 black combo (not 62150N Deluxe silver) on XP Pro for years with no problem. Manual said to sync, press ID button on receiver and LED will blink fast, then slower. While blinking, press ID button on keyboard and mouse (need pen or something to press mouse button). If receiver LED blinks whenever you move mouse or hit keyboard, it is receiving. If OS doesn't recognize, may be connectors. I had 2 separate PS2 ports and had to use an USB adapter for the keyboard cable.
Mar 24, 2008 | Computers & Internet
Compaq keyboard
my keyboard just stopped working. i tried troubeshooting but it hasnt helped.
Oct 21, 2007 | Compaq Keyboard
Aug 17, 2007 | Sakar 62150 Keyboard
Sakar 62150 Keyboard Logo
143 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Argospete
Argospete
Andrew
Andrew
Level 1 Expert
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
